Tecarc 206i mma welder
Discussion in 'Classifieds Discussion Area' started by rustynlc, Oct 8, 2013.
  1. rustynlc
    Offline
    rustynlc Member
    Jul 5, 2011
    141
    9
    [Oct 8, 2013]
    Tecarc 206i mma welder inverter, bought new 7 months ago, like brand new still, no longer need as i have a gas/gas less mig I use, so this is surplus to my needs, below is specs copied from tec arc website, this comes with box and manual, it doesn't come with electrode lead or earth clamp lead but these are easily obtained through the Internet or tool shops,&nbsp;<br>Can take to ADI or cash on collection only due to weight, westbury/Wiltshire&nbsp;<br><br><div>This rugged machine is designed for heavier MMA electrode welding than our popular MMA166i or MMA165i models.</div><div><br></div><div>Ideal for all fabrication or maintenance applications, this model is also very portable so is ideal for site welding. Built in hot start ensures superb arc striking of electrodes with a super smooth welding arc. Large Dinse style cable connectors are fitted to give the best reliability. These machines are constructed using Toshiba mosfets &amp; other quality parts with a large safety margin for the best reliability. These are a well proven range of arc welding machines with 1000s sold.&nbsp;</div><div><br></div><div>Generator friendly &amp; can be run from up to a 50M extension cable with only 7% loss of power (2.5mm cable) or up to 100M extension cable in 4mm cable with around 7% loss of power.</div><div><br></div><div>Optional TIG torch kit available for this model.</div><div><br></div><div>Optional MIG wire feeder available for this model.</div><div><br></div><div>Built to comply with BS EN 60974-1, CE marked, RoHS compliant and WEEE registered so you can be sure of the safety &amp; quality.</div><div><br></div><div>Technical Spec</div><div><br></div><div>Supply Voltage 230V</div><div>Fuse (slow blow)* 16A</div><div>Generator size min 6KVA</div><div>Welding current range 20-200A</div><div>Max (OCV) 60V</div><div>Max recommended rod 4.0mm virtually continuous (5mm max)</div><div>Duty Cycle 200A @ 40%</div><div>Size approx 390Lx280Hx150W</div><div>Weight Approx 9KG</div><div>Protection IP23</div><div>*When using with a 13A fuse above 150A MMA the fuse may blow occasionally.</div><div><br></div>
    #1
  2. Ads
    Ads
    [Sep 17, 2014]
