Tear in pipe - part number???
kitpayne Sep 23, 2009
  1. kitpayne
    kitpayne Member
    129
    hey guys, i fitted my forge DV today and whilst doing so i noticed i had a tear in this pipe. :sob:
    any ideas of the part number or what its called so i can get a new one?????
    thanks in advance.
  2. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    Check out VAGCAT.COM
    I think it is part 13: (13A) 06A103221AC
    breather hose
    / AMK,BAM
    As I had to replace this on my 2002 S3 when the hose split. You can turn the tube around to see the part number or take it off and have a look only takes a couple of mins to do and is very straightforward to replace.
  3. kitpayne
    kitpayne Member
    129
    i just got my copy of ETKA working and that was the part i was looking at. thanks for the confirmation. cheers :beerchug:
  4. kitpayne
    kitpayne Member
    129
    just rang audi - £34 for a new one :faint:
  5. jesters3
    1,516
    Yeah, looking back it cost me £32.99 from Ridgeway Audi!
  6. 1animal1
    9,978
    that part doesnt look the same on the chart you've posted jest
  7. jesters3
    1,516
    I'm pretty sure it is, the 'hose' above with the Oil Catcher is not connected and that goes off to the TIP - I had to change that one as well as it had a split too!
  8. 1animal1
    9,978
    na the one highlighted is the one to the TIP from the rocker cover...but it twists upwards so as to reduce oil being transferred to the TIP.... you r diagram doesnt show a similar pipe?
  9. ianysm
    ianysm Active Member
    1,002
    Number 15?
  10. 1animal1
    9,978
    nope cos the offending pipe goes from the rocker cover to the one way valve that fits onto the TIP....
  11. ianysm
    1,002
    Oh!
    Number 13? :)
  12. jesters3
    1,516
  13. ianysm
    1,002
    Out of interest, does this tear in the pipe cause poor running?
  14. 1animal1
    9,978
    possibly because its part of the vacuum system.........
    Jest yeah your right , i changed my last post cos the bendy pipe goes to the non return valve and also directs down to the bottom end to recirculate the oil back into the engine...still dont think its on the chart you've posted though....the rocker cover doesnt match for a start ;)
  15. jesters3
    1,516
    It'll produce the 17705 code on VAG-COM
    The part is the 13a part for sure - it doesn't show the rest of the connecting parts though hence the confusion. Took me a while to figure out so just pulled the offending hose off and looked at the part number - a much simpler way!
  16. 1animal1
    9,978
    :icon_thumright:
  17. kitpayne
    kitpayne Member
    129
    that was actually the wrong part number for my engine Jester. The part number i needed was 06A 103 221 N. thats what it said on the pipe. audi got me the part with the number you gave me but it looked just as in the diagram, must be a different engine or something. I got the new part and fitted it now so all sorted anyway. Cheers though. :beerchug:
  18. 1animal1
    9,978
    what did it cost you in the end payne?
  19. kitpayne
    kitpayne Member
    129
    should have been £20.85 + VAT but i know a sales man at my local audi so got discount and i paid £21.59 only 12% discount!!!
  20. 1animal1
    9,978
    yup i managed to get 10% over the counter once myself.... they try and stiffle ya regardless of being trade or not
