TDi question
qennu Nov 23, 2009
  1. qennu
    qennu Member
    178
    Hello I know this was asked millions of times before.I am looking for an audi and found an 05 model (not with the single grill fron bumper :sadlike:)I dont mind so much as I can be changed later on.It has 60k on the clock.How can I be sure the milage is right and not played with earlier ?
    What are the most important things to look at other then accident damage ?
  2. V6Pete
    V6Pete Now running on Bentley's y'all
    1,491
    If it has FSH and preferably previous MOT's, then it's likely the mileage is genuine.
    If it doesn't have FSH, then walk away and find one that does!
    Also don't worry about the single grill, it'll grow on you ;)
  3. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,473
    610
    The mileage on the new vags is very hard to clock if even possible at all - I cannot remember of any cases where the latest vags have been clocked!
    TDI's checklist
    Check for being juddery at idle
    Floor the accelrator in 6th at 50mph to check for clutch slip
    Has the timing belt been done? (personally I would have it done at 60k as opposed to audi's 80k recommendation)
    Usual wear and tear
    Check oil levels
    Check for next service on the DIS
    The twin grill will grow on you - I had a twin grilled A3 TDI before my S3 and loved it with a few choice modifications including Audi Votex splitter kit!
    Check them out!
  4. qennu
    qennu Member
    178
    The car will be shipped to malta.Here labour works dont cost alot like in the uk so I dont mind giving it a full service for a pieces of mind ie:timing belt,water pump etc.Also car will be having an s line kit with a single front grille.Dont mind changing the clutch as I will put and uprated one to cope with the remap lol.
    I am more worried about rust issues.Ok I know these cars come with a 12 year gurantee (I think) but I was told uk cars above London do rust more because of the weather,(dont know if its true).
  5. V6Pete
    1,491
    Yeah I was nearly put off buying my A3 because it came from Newcastle originally, and the Geordie weather isn't great. I gave the bodywork a thorough inspection before buying, and apart from a few empty bottles of 'broon' in the boot, it could almost have passed as a more desirable "Southern car".
    You don't have to draw the line at London though, anything south of Watford Gap should be ok.
  6. qennu
    qennu Member
    178
    car is in Leicestershire.hows the weather there ?
  7. V6Pete
    1,491
    If it's the Market Harborough end, then you're fine, as that's almost Northamptonshire. If it's Loughborough way, that's nearly Nottinghamshire, so I'd make sure it was fairly thoroughly inspected.
  8. qennu
    qennu Member
    178
  9. V6Pete
    1,491
  10. Boydie
    3,473
    610
    Never heard the likes of a car being more rust prone because its north of london lol it shouldnt put you off buying a car though!
  11. V6Pete
    1,491
    Spoilsport. :asskicking:
  12. qennu
    qennu Member
    178
    dont know if its sold I guess it wont be on ebay anymore.I contacted the seller but no reply yet,also its still listed on their website.
  13. FUNKYCLIFF
    FUNKYCLIFF Member
    185
    If you want to check the history out get the reg of the car i notice it is a private plate though, or get the vin number and you can ring Audi Uk and they will do a service history check by vin number or reg plate i suspect you may want to get the vin number as Audi may not have anything listed with the private plate. If the trader asks what you wnat it for just tell him you HPI checking it before coming over, he shouldnt object to that if he is honest
  14. FUNKYCLIFF
    FUNKYCLIFF Member
    185
    Audi uk customers services 0800 699888
  15. qennu
    qennu Member
    178
    does audi a3 tdi come with air condition as standard or its an option ?What
  16. qennu
    qennu Member
    178
    does audi a3 tdi come with air condition as standard ?What other extras are standard and do they vary between the single and split grill ?Thanks
  17. pdv40
    pdv40 Member
    187
    :haha:
