tdi problems
maxiking Oct 9, 2005
  1. maxiking
    maxiking New Member
    Hi i have had a problem with my tdi audi 80 for over a year now . It kicks like mule intermitently , all the fuel lines have been swapped so not air getting in . injectors cleaned all ok and the air filter changed anybody got a clue please help. /ubbthreads/images/graemlins/cry.gif
  2. tubtub
    tubtub Member
    160
    It's often the MAF sensor (see other thread).
  3. maxiking
    maxiking New Member
    Hi just in case anyone has a similar problem it wasnt the airflow meter?
    When i had taken the pipes off everything inc the inlet manifold was really crudded up a pain to get off but once cleaned is 100% better.
  4. imported_5u8z3r0
    imported_5u8z3r0 Guest
    Sounds like injection pump. Would need to really see and experience the fault to be 100%, but the way you have descibed it, and my experience leads me to suspect the pump.
  5. johndow
    johndow New Member
    10
    Is it running too rich? Should clean itself if you give it a good blast every now and again.
    Are you running a remap/ chip/ tuning box?
    JD
