Tdi oil pump drive
Gillm Nov 15, 2013
  1. Gillm
    Gillm Member
    110
    Just wondered if you guys are aware of these wearing and causing oil pump failure ? Mine is in having a service and a new drive as a precaution . My friend who is a ex vw master tech who now runs his family business was telling me the horror stories from when in vw .
    The part is about £8 but sadly 5 hours to fit it and he recommends.it being done every 60/70k
  2. NHN
    29,417
    1,740
    Really, on a B8, I only know of the previous chassis being so problematic.
  3. Gillm
    Gillm Member
    110
    Yeh b8 . The early drives are hollow and the later ones are solid and hardend . I'm picking up the car tomorrow so will grab the old drive
  4. hollow
    hollow Well-Known Member
    1,404
    162
    your missing the half of it , if your mate knows his stuff then he will know that vw/audi changed the whole oil pump drive part for a newer one . i bought the part myself at a cost of £250 exchange ,the part you are buying is just a plain old allen key with the end cut off basically .and yes it does have a hole in the old one but it does not cure the problem that i can guarantee .
    the new drive and key are modified the key is 100mm long where the old one is approx 75mm long ,the drive is redesigned so that the keyway is alot deeper and the key is a very tight fit .
    old design only allows key to insert around 10-15mm and is loose even when new . my advice would be to fit the whole new part ,you have to do the same amount of work to get to it . and the new part has a lifetime unlimited mileage warranty against failure .
  5. Gillm
    Gillm Member
    110
    So what did you get for £250 ? A new oil pump or drive ?
  6. hollow
    1,404
    162
    for the £250 now £225 you get the allen key plus the new balance shaft ,you need to change both these parts for it to be bullet proof .
    ive honestly seen a 6mm allen key cut down and used as a bodge on the older b7 models .
    have a look on ebay for balancer shaft repair
  7. vw754
    vw754 vorsprung Durch Technik
    2,345
    58
    :scared2: thort thes tdi cr engines were bullet proof !
  8. hollow
    1,404
    162
    so did everyone else ,but they aint !!!
  9. vw754
    2,345
    58
    anyone know how much all this costs,any pics of the item,any symptoms/mileage/year?
  10. hollow
    1,404
    162
    replacement parts cost £225 ,no idea what they will charge to fit in your neck of the woods . symptoms are low oil pressure light on
    mileage 80,000 upwards.
    look on kmbpartsdirect and look at the balance shaft kit
  11. vw754
    2,345
    58
    so if low oil pressure light ever comes on...stop engine and get em done?
    sell mine before 80k lol only on 60k yet and i only drive 6-7k a year
  12. Gillm
    Gillm Member
    110
    It's 5.5 hours work as the subframe has to be removed . And as with any oil light turn the car off that instant
  13. a43.0v6tdi
    a43.0v6tdi Dave
    37
    What engines does this effect?
  14. hollow
    1,404
    162
    the tdi common rail engines in the b8 made before sept 2009
  15. a43.0v6tdi
    a43.0v6tdi Dave
    37
    Sorry to be potentially thick here but would that extend to the b8 '08 3.0 V6TDI also?
  16. vw754
    2,345
    58
    never heard of issues with the 3.0 tdi....but there are issues with the auto box's that many 2.7/3.0 tdi come with a lad i know had his tt one done twice,a4 one done 4 times! first time at 13k miles last one after 60k
  17. offpist
    offpist Member
    32
    22
    I have an 2008 mod A4 B8 With the 2.0 TDI going on 170 000 km now.
    One more thing to worry about.
  18. vw754
    2,345
    58
    that around 106k?..........im not worried,mines just turned 60k.........plenty on sale on e-bay ranging from 50k to 188k.........im sure they all NOT had the failure.
  19. brownie 25
    brownie 25 Member
    383
    9
    RESURRECTION.......
    is this the same engine that is in the late 2008 vw passat ?
  20. hollow
    1,404
    162
    yep and its **** ,also happens on the early common rail engines too.
  21. Jenno
    Jenno New Member
    24
    Anyone know if a mid 2009 A4 2.0 143 engine code CAGA is affected ?
  22. vw754
    2,345
    58
    Yes.........dont worry im in same boat....not many b8's plent for sale on e-bay upto 190k on them when i searched all 2008/9 models.........ive stopped panicking mate,plenty of rumours,but who knows how theyve been maintained?
  23. Jenno
    Jenno New Member
    24
    Im told my A4 has the later Gear Driven Mechanism (registered May 2009) is this still affected ?
  24. vw754
    2,345
    58
    The rumour is yes........only safe after oct 2009....dont panic we have the same engine:salute:
