tdi injector duty problem
nokia_aid Nov 7, 2011
  1. nokia_aid
    nokia_aid Member
    47
    iv got a bad/smokey cold start problem with my car,vag com brings up a misfire on cylinder 1 and when i checked injector duty i have
    cyl1 cyl2 cyl3 cyl4 measured in mg/str
    2.99 -3.01 -0.19 0.14 as it the car got warmer they went to
    2.82 1.6 -0.73 -0.45 and then when i had been driving for about half an hour it was at
    CYL 1 CYL 2 CYL 3 CYL 4
    1.71 -0.74 0.72 0.42
    anyone have any idea what could cause this,
    iv already tried changing injector 1,
  2. towcestervag
    towcestervag Member VCDS Map User
    165
    run some injector cleaner through fuel system
    ive had a few do this and its due to carbon build up on the end/nozzle of injector
    if its a 2.0 tdi then it may need injectors
    prefix d and m are the ones at fault
  3. durtytdi140
    durtytdi140 Member
    66
    injector loom problem mate im going to change mine it happens because the injector loom wiring overheats and melts because the wiring is runnin so close to the cars head where the boiling hot engine oil is which causes the injector to nozzle and injector to work sluggish showing the cylinder as if its going down but its usually just the loom but if your unlucky then you may need to do the head/full injector
  4. nokia_aid
    nokia_aid Member
    47
    ok i changed the injector loom and that didnt fix it,i also did a compression test and that came up ok,
    what else could it be that causes the injectors to do this real bad when cold but then goes within tollerance when engine is properly warmed up
  5. nokia_aid
    nokia_aid Member
    47
    iv just checked and when its totally cold from first start cyl 3 is like it too and cyl 4 compensating
    cyl 1 cyl 2 cyl 3 cyl 4
    2.99 -3.01 2.79 -2.78
  6. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    Run injector cleaner, check all connections are clean and getting a good contact on the injectors. Other then that the solinods on the injectors are probably starting to die which means new injector/injectors.
  7. fangio
    fangio Well-Known Member
    1,472
    174
