TDI Hybrid Turbo considerations
heyadamhey Jan 12, 2010
  1. heyadamhey
    heyadamhey Member VCDS Map User
    126
    Hi guys
    I seriously considering getting the hybrid treatment done on my turbo.
    How necessary is it to upgrade the following:
    Fuel system? (pump, injectors, anything else?)
    Clutch? (apparently a good idea to get an uprated clutch)
    Intercooler?
    Exhaust?
    Obviously a remap
    What other considerations are there?
    Adam
  2. heyadamhey
    126
    so after doing some more phoning around, it seems the possibility of having my turbo 'hybridised' is not an option here in SA :(
    but... I did find out that the Taureg V10 uses two VNT1852 turbos. surely one of these would be very close to the GT1749 with a 52mm exhaust wheel?
    Does anyone know if this'd work? presumably a new manifold would be in order, but is it worth considering as an alternative to having mine milled out?
  3. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    http://audi-sport.net/classifieds/s...rbo-with-manifold-and-decat-down-pipe-&cat=15 :whistle2:
  4. madluke
    madluke In pursuit of audiness:)
    276
    thats for me:))))
  5. devonmikeyboy
    1,245
    Now provisionally sold to Madluke who`s girlfriend is :hubbahubba:
  6. heyadamhey
    126
    If postage to South Africa wan't an issue and it being sold wasn't an issue, you'd have had a buyer, Mikey.
    any thoughts on the GT1852V ? I noticed another user on here has one fitted to a 2.0TDI
  7. devonmikeyboy
    1,245
    Good turbo but what power do you want to be make ?
  8. N8
    17,163
    719
    The pic Luke showed me, I was abit :undwech:
  9. heyadamhey
    126
    similar to the 52mm you suggested, I guess. 220ish bhp.
    I just can't find anywhere in South Africa that will modify my current turbo...
    If I did go with that, would my clutch handle?
  10. madluke
    276
    N8 lie lie and lie some more:D you jealous K(C)ow:D
  11. N8
    17,163
    719
    :Flush::shutup2::laugh:
  12. sijones
    sijones Member
    160
    With the hybrid you lose below power 2500rpm, but there is awesome amount of power from 2500rpm right to red line...
    So when driving you have to drive differently and change down to get the turbo in because 5th an 6th the revs will be out of the turbo range... this is after a remap as well...
    Am waiting now for mine to settle to see how the MPG is affected...
  13. sijones
    sijones Member
    160
    PS - Nope... mine slips in 4th 5th an 6th with foot down hard... but driven carefully and not hammered all the time you'll be ok for a while...
  14. heyadamhey
    126
    Ok, so I finally found a place that will modify my turbo and remove the cat, but they don't do remaps.
    Would it be driveable before getting it remapped? i.e. would it just constantly go into 'limp mode'?
    Would the decat throw any ECU errors? I've heard people mention the lamda sensor (?)
    Adam
  15. sammi
    sammi Active Member
    345
    45
    I am no expert but would have thought it would need mapping to run safely as I am sure the boost levels will be increased over standard. If you are careful and stay off the power then you should be ok for a short period of time
  16. devonmikeyboy
    1,245
    The turbo can be run without a remap but will be very laggy and will not make much more power then your stock turbo plus if you try to drive it hard it will go into limp mode. Removing the CAT will cause no problems at all as with it being a diesel it has no censors in the CAT. Untill you sort out where you are going to get a map from no point really fitting the hybrid turbo. If you buy yourself something like an Alientech box http://www.alientech-to.it/index.php?option=com_content&task=view&id=6&Itemid=13 like i have you can get maps emailed to you and upload them yourself.
  17. heyadamhey
    126
    Thanks guys - was really just checking if I'd be able to drive if from the turbo shop to the garage to get it remapped...
    Thanks for the link, Mikey, any idea on what they go for?
  18. devonmikeyboy
    1,245
    In England you can buy it for £295 with a sports, economy and standard map already on the device.http://www.tuningtools.co.uk/alientech-powergate-ford-obd-tuning-information.html. Several "remap companies" already sale the device rebranded as their own device with their "own" maps on like Chipped UK ( now changing their name to Viezu ) who call it a ST3 http://www.chippeduk.com/content/en/Services/ST3_-_Self_Tuning_System.html , Derv Doctor,RS Tuning etc . I bought the device direct with no maps on for £150 from Alientech.
  19. N8
    17,163
    719
