TDi fuel tank sender
B5NUT Jan 10, 2014
  1. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group s tronic
    3,885
    720
    This morning when I left my car I had 100 mile left in the tank, when I started it up this afternoon the DIS and gauge stated 0 and the fuel light was on, I went to the garage and put £15 as I just wanted to make sure that there was some fuel for the trip back. after putting the fuel in the tank the gauge barely moved and the DIS range stated on 20 miles till empty.
    Anyone else had a similar fault, and if so did you just buy a new sender unit form Audi or did you find an aftermarket part, as looking at etka I get part number 8D0919673J and after a quick search on ebay and google it looks like an Audi only part.
    I take it best to change it when the tank is just about empty.
    Car is a 1.9 TDi AJM
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,163
    1,123
    I had the same sort of issue with mine but it seem to have sorted it self out after several full tanks.
    I did read that the sender cable splits and causes false readings.
    Wait till the tank is low,remove the sender and make sure the cables and connections are ok.
  3. B5NUT
    3,885
    720
    I brimmed the tank this weekend and gauge went to 3/4 of a tank, then over the course of a few miles the gauge crept up to full. I've rest my trip and will keep an eye on it, but so far so good.
  4. ScottD3
    15,163
    1,123
    That's pretty much what I did.
    sorted it self out now.
    I will pull the sender out in the next several months to make sure its ok.
  5. B5NUT
    3,885
    720
    If it happens again I'll just rip it out and replace it, just could with it lasting a little longer until the weather improves.
