TDI 2.0 Turbo screech time to upgrade?
Matt_Storm Jun 7, 2008
  1. Matt_Storm
    Matt_Storm Member
    34
    Hello im new to this forum but have been searching various sites for an answer to my problem so i hope someone can finally help.
    I have a 2004 a3 2.0L tdi sport was originally 140bhp and was rolling road remapped six months back to 185bhp with no problems, until now.
    The turbo has started this nasty high pitch screech when it cuts in its so bad i had tinitus the other night after a drive, i am guessing the bearing is going it still pulls but not as well.
    My question is, as i need to replace the turbo can anyone tell me if a larger turbo from a tdi 2.0L 170 quattro will directly fit mine or do i need to change other parts?
    I am only thinking the larger unit may be better as its designed for the more powerful engine and i dont want to damage another standard 140 turbo if re fitted.
    All feedback appreciated!
  2. treblesykes
    treblesykes Member
    690
    earplugs?
  3. Matt_Storm
    Matt_Storm Member
    34
    Yep good one. Anyone else know?
  4. mattysupra
    mattysupra Big BHP!
    73
    cant help on the turbo fitment. But why dont you think about having your old turbo repaired with better bearings, stronger shafts ect. Hybrid basically. I would also think about speaking to the people who mapped your car. You will have to have car mapped again for a different turbo. You might not want to drive it either. If the turbo breaks up you might be looking at a engine build aswell!
  5. Matt_Storm
    Matt_Storm Member
    34
    I was thinking of a rebuild but i have the chance to buy a turbo from a 170 model so was wondering on the fitment.I was thinking that just a bigger charger will boost the same for the engine how its currently set up as its demand etc with the capability to increase the boost later on?
    I might just get it and hope for the best, the manifold fitments are the same aparently its just the rest i am unsure of.
    Thanks for the advice!
  6. dunk
    dunk Member
    770
    the turbo and exhaust manifold are an integrated item - i presume (dont know) that the 170 turbo would fit.
    increasing the boost or fitting a larger turbo will do nothing on a diesel without a remap - the engine basically gets lots of air (there isnt a throttle valve in the same way as a petrol engine), but the torque/power is controlled via the amount of fuel - hence the remap to put more power in and why a simple resistor to enrich the mixture can create so much extra power
    a hybrid rebuild from Allard (vt2) or turbodynamics (MD375) is a bolt-on replacement but has the same hot side with suitable modifications, and a much larger cool side to pump more air, both for a given pressure and can run higher boost pressures.
    a rebuilt hybrid turbo should cost about £450 plus vat exchange and about £950 plus outright brand new, and then about 3 to 4 hours labour for a turbo swap
    a big turbo remap will cost about 500 or so, and you should have a decat or high flow cat to keep the new turbo cooler. some tuners might suggest a high performace exhaust but i dont think this is as necesary as the decat or high flow cat.
    overall you should get about 210-220hp from the vt2, and 230-240 from the turbodynamics with a good remap, exhaust and decat.
    dont bother with a performace air filter - they are worth nothing,
    if you just fit the big turbo with standard map or a remap you will get exactly the same performace as a standard turbo (without the screech!) and can remap later.
    jakeyb2525 likes this.
  7. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    The PD170 turbo is basically the same as the PD140 turbo just clocked to sit at a different angle on the engine so you will not gain anything over the PD140. The PD170 gains the extra power with different more effective nozzles and a slightly more agressive map.
    Allards VT2 turbo which is no longer available was/is good for 230 bhp and i had one running 260 bhp back in 2005 on my Seat Ibiza Cupra PD160.
    Turbo Dynamics do a range of hybrid turbos.
    Set 1 - PD130
    Stage 1 = MD345 = GT17 compressor wheel.
    Stage 2 = MD446 = GT20 compressor wheel.
    Set 2 - PD150
    Stage 1 = MD374 = GT17 compressor wheel
    Stage 2 = MD376 = GT20 compressor wheel
    Stage 1 – MD374
    Hi flow GT17 compressor wheel, cnc machined compressor housing, 360 degree thrust bearing, cut back turbine blades, lightening of turbine wheel for faster ‘spool up’, modified V.N.T. turbine housing, uprated turbine seals. Other ‘blueprinting’ modifications. APPROX 200 - 220 BHP
    Stage 2 – MD376
    Hi flow 2275 spec compressor wheel, cnc machined compressor housing, 360 degree thrust bearing, cut back turbine blades, lightening of turbine wheel for faster ‘spool up’, modified V.N.T. turbine housing, uprated turbine seals. Other ‘blueprinting’ modifications. APPROX 240-260 BHP
    Stage 1 £925 plus VAT for new unit
    Stage 2 £975 plus VAT for new unit
    Removing or replacing the back box with a free flow version is a lot more important then removing the CAT as it`s the stock back box that is the restriction in the exhaust system not the CAT.
