TDI 170 & DPF delete = MOT pass
jrsteeve Apr 30, 2012
  1. jrsteeve
    jrsteeve Member
    136
    Just thought i'd pass it on, mine was tested last week and passed with no problems on the smoke test. Myth = busted.
  2. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    Good work mate.
    Although it will not fail on emission tests, there is talk about a visual inspection in the future, and this is where you will get failed on. But if you know a guy that does MOT's, then Happy days!
  3. jrsteeve
    jrsteeve Member
    136
    They'd have to take a blow torch to the DPF holder bit to check that! Plus the remap is software, so again not much to look for.
  4. PhilM81
    PhilM81 Quattro, bring on the SNOW!
    84
    JRS, where did you get your delete done? cheers.
  5. DixonH
    DixonH Member
    31
    I've spoken to an MOT tester mate and the visual check is if the DPF is completely removed, i removed mine cut it open then gutted it carefully and welded it back up. it took quite a few hours as its a Quattro but is well worth it and it only cost an extra £50 on top of my custom map cost to remove the regen coding.
    Its well worth it and still looks stock unless you remove quite a bit of stuff like the driveshaft and driveshaft heat shield to see the weld.
  6. TripleD
    TripleD Audi S4 Avant Owner Team Mythos Audi S4
    711
    245
    43
    Does it make much difference to power / MPG?
  7. jrsteeve
    jrsteeve Member
    136
    Done at BVR automotive near Stafford, had a few issues with a duff sensor shortly after it was done but it's been fine now since November when it was done. The main difference is that it revs quite a bit higher (it's the s-tronic) and generally seems quite a bit quicker. Can't say i've noticed a difference in mpg, hadn't owned it long before it was deleted as the dpf blocked up about a week or 2 into ownership (duff sensors!!!!). If it helps i went from Manchester to Plymouth and back on a single tank, still had a little left too.
    The original piping/casing was kept, only the dpf removed, then welded back up so it looks standard ;)
  8. Old-Boy-Racer
    Old-Boy-Racer Guest
    Good to hear I had mine remapped by R-Tech a month ago and they did the full DPF removal (cut in half, innards removed, welded back up and replaced). Map improved it from 170 to 205 and the torque is stonking. Taking a bit of getting used to but is great fun - wheelspin in 4th in the wet if I lose concentration!
