TDI (140) DSG - Mpg drop?
sibby Jun 4, 2008
  1. sibby
    sibby Member
    76
    Over the last couple of weeks I have noticed how my mpg has gone between 30-40 and sometimes 29, out of half a tank of fuel I am lucky to get 200 miles before reserve tank. Often only getting about 160-180 miles!
    Prior to this I would leave it in sport mode and even after 10 minutes of revving each gear to the max and driving harshly it would still be around 35+ mpg!
    Anyone have any ideas? I have about 6 months left on my warranty so may give Audi a call but would prefer not to!
    Some info:
    - A3 S line TDI 140 DSG
    - Use standard BP diesel
    - Lots of town driving / short journeys
  2. Boydie
    Boydie Guest
    Thats your main problem...short journeys
    Try these simple solutions:
    Disconnect battery for a short time
    Replace deisel filter
    Replace Air filter
    Oil change
    If you know someone with VAGCOM - get them to check your faults and reset the unimportant ones - i found this to increase my mpg for some reason - strange
    I have 175bhp (140pd), 19" wheels and a full sound system and get high 40's most of the time!
  3. sibby
    sibby Member
    76
    Not sure about the battery but the diesel/air filter and oil could help. I will look into these, the car is 2 1/2 years old so nothing major (usually) needs replacing!
  4. bacardi
    bacardi Active Member
    1,139
    I've never noticed mine get lower than mid 30's in traffic, overall its still averaging 48 on DIS. Weekday driving is a good mix of motorway and stop start - I'd give your friendly local dealer a call and ask them to check it out
  5. Boydie
    Boydie Guest
    I am 44mpg overall I think!
  6. bacardi
    1,139
    I'm amazed with mine if I'm honest
    It gets absolutely leathered everywhere it goes, and I mean leathered
    still (according to DIS) averages 48 - I guess one day I should really measure it myself rather than trust DIS
  7. Boydie
    Boydie Guest
    I have covered 70k miles though
  8. sibby
    sibby Member
    76
    How about actual mileage (on the clock not DIS) from half or a full tank?
  9. OllyjoyA3
    OllyjoyA3 A3 Audi S-Line
    I am getting 55mpg in mine! awsome!:redrs4:
  10. bacardi
    1,139
    mine's now on 72k, takes its time starting in the morning, think it wants to retire soon
  11. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    Be worth a trip to the dealers as it is still under warranty as there is something amiss.
    For example I had the coolant temp sensor go on mine and it didnlt flag any errors on the dash.
    The Engine ECU knew there was a problem though.
    Paul
  12. Amchlolor
    Amchlolor Active Member
    5,604
    My A3 sometimes only did 7 miles a day (3.5 miles commute).
    Combination of sitting in traffic, then revving the paps off it on a short stretch of country road.
    I still got around 40mpg(ish).
  13. sprout99
    sprout99 Member
    373
    I DON'T BELIEVE YOU !!!
    don't believe the DIS - it's full of ****
    We get 45 ish if we drive like miss daisy and most of that is on dual carriage way
  14. sibby
    sibby Member
    76
    I dislike going to the dealers for anything, they always damage something :keule:
    Even with all my short journeys it never went to low 30/28-29 mpg.
    Tomorrow I will check everything is normal ie coolant, oil, etc didn't get a chance today! Then I will take it on a stretch to see if it improves, if not off I go to the dealer :haudrauf:
    Thanks for info so far! also my DIS has been very accurate, I also track it by looking at the actual mileage and that has become poor too!
  15. sprout99
    sprout99 Member
    373
    If we drive ours with a random amount of thrashing it will do 40mpg
    If we drive it nice all week we get 45mpg.
    VAGS always were top at mpg until the 2.0TDI came along .
    The other 1.9 130PD A3 we have returns 50mpg with lots of thrashing.
    The older car is not Euro 4 compliant and has 95k on her.
  16. nhowroyd
    nhowroyd Member
    128
    On a similar theme.....
    I am expecting delivery of my A3 Sportback SE 2.0 (140) TDI S-Tronic.....
    How many miles should I expect from a tank and do I need to run it in or can a cane the backside off it from the get go..
  17. bacardi
    1,139
    cane it, I did and mine's (engine wise) been fine
  18. nhowroyd
    nhowroyd Member
    128
    What mileage do you get from a tank.......
  19. bacardi
    1,139
    according to DIS it reckons 550 ish, it actually manages something nearer to 450, unless the wife drives then it could possibly make it to the moon and back on a tank :)
