TDI 130 Brake Upgrade?
Mollygoogle Feb 22, 2013
  1. Mollygoogle
    Mollygoogle Member
    262
    10
    I have a 2002 TDI 130 saloon with 288mm fronts. Am I right in thinking that if using the front carriers from a 2004 2.4 cabby I can switch to 312mm? Is it right that my existing calipers can be used on the 312mm set-up? Will I gain much difference in braking performance by doing this?
  2. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    I got my 312mm carriers off a 3.0
  3. Mollygoogle
    Mollygoogle Member
    262
    10
    Thanks for that. I've been having a good search through the site to get more info. The one question none of the threads seem to answer though is whether there is much improvement by moving to the 312mm disc?
  4. Mike.M
    2,510
    170
    Stopping power improved for me......you just don't need as much effort on the pedal when braking if that makes sense.
    They also fill the wheel better and visually look nicer being larger too LOL
  5. Mollygoogle
    Mollygoogle Member
    262
    10
    Thats all I needed to hear, thanks :D
    I need new brakes and I'm switching to 18"s so it seems the obvious thing to do
  6. Mike.M
    2,510
    170
    That is what happened with me
