TDI 100's. They PD?
emzino Sep 22, 2006
  1. emzino
    emzino Active Member
    1,231
    As topic asks, are the TDI 100's PD or not?
    Ta.
  2. Macduff
    Macduff Member
    742
  3. emzino
    1,231
    Nice :D Thanks Macduff.
    Just that the A3 TDI 130's are too damn expensive. I can get a B6 A4 TDI instead. Not the same speed but more luxury I think.
  4. a4quat
    a4quat Member
    374
    what does pd mean
  5. Macduff
    Macduff Member
    742
    Pumpe Duese (I think that's the correct spelling) i.e. the very high pressure pump injectors that are found on the 1.9 100, 115, 130 & 150 and 2.0 140 & 170 engines. 1.9 90 & 110 plus I believe the older 2.5 TDIs use a single distributor pump at much lower pressure.
    On the PD engines the pressure is created by a camshaft driven pump for each cylinder. At the right moment, the injector is electronically activated. The new 2.0 170 engine uses piezo activation while the 1.9 and 2.0 PD engines use solenoids. The piezos give faster response time allowing better control of the fueling. The newer 2.5, 2.7 and 3.0 TDIs are all common rail with piezo injectors (I believe). No idea about the 4.2 in the A8 but since it's a recent engine I imagine it's also common rail with piezo injectors.
