tc light on
sfield Dec 31, 2013
  1. sfield
    sfield New Member
    19
    got tc light on and man light on been told its the maf sensor can these be cleaned or are they easy to replace have had a kn panel filter in it mines a 2003 bam engine
  2. Broken Byzan
    13,237
    465
  3. epox
    epox Active Member
    772
    74
    I had the tc light come on with a faulty mad, the light only stayed on until the ig notion was switched on and off then rests for a while.
    If you are getting a new maf get one from tps.!!! I have 4 cheep eBay ones and a ecp one in the garage....
    Lesson learned
    Mark
    ps i think it was too muck oil on my filter that killed the maf
  4. sfield
    sfield New Member
    19
    thanks for that will give it a clean 1st
  5. epox
    epox Active Member
    772
    74
    Try unplugging it and see if the car runs better. Maf I mean.
    Mark.
    Vcds lite and cheep eBay cable or full vcds is a must.
  6. sfield
    sfield New Member
    19
    will it run with it unplugged
  7. <tuffty/>
    20,847
    3,687
    I would also scan for fault codes regardless
  8. sfield
    sfield New Member
    19
  9. sfield
    sfield New Member
    19
    had it scanned today showed up air mass sensor
  10. epox
    epox Active Member
    772
    74
    Should do, if its a maf fault although I did have to clear existing faults one time though.
    As tuffty says would check for faults with a scan
  11. <tuffty/>
    20,847
    3,687
    Ok... what was the actual code? makes a difference as there are a few MAF related codes and not all are due to a problem with the MAF..
    As already suggested though the TC light staying on is typically due to a knackered MAF but its always a good idea to scan first, post codes and go from there
