Tar Remover before Claying
Scott_Hol May 20, 2011
  1. Scott_Hol
    Scott_Hol Member
    584
    Hi
    As title states do i really need to use tar remover before claying aslong as i lube the car well? obviously most of you would recommend it but i havent got any ready for a good detail tommorow. Depending on replies ill probly pop to halfords tommorow, they sell it right?
  2. DaveyB
    DaveyB No misfires.
    269
    It all depends what state your motor is in mate I suppose but using a tar & glue remover is going to strip whatever protection is on there right back and so you will be starting from scratch with the bare paint. If your using a fine clay like megs its only going to strip whatever protection you have partially. I dont think it matters how much lubricant you use, if the tough stuff doesn't want to shift it's going to stuck no matter how much lube you chuck at it. It's always good to use plenty of lubricant but it isn't going to do the job of Tardis or something similar.
  3. Scott_Hol
    Scott_Hol Member
    584
    Paint work isnt in bad condition just want to get all the road tar off as there are quite a few black spots on the side just dont want them to make the paint work worse when i clay over them
  4. DaveyB
    DaveyB No misfires.
    269
    Fair do's, in that case I would source some tar remover then. It isn't going to hurt and it will make the job of claying that much easier.
  5. Scott_Hol
    Scott_Hol Member
    584
    YOU HAVE ANY IDEA IF HALFORDS SELL IT M8?
  6. DaveyB
    DaveyB No misfires.
    269
    They will sell something that doest the job yeah, Autoglym or something similiar is probably the best you can hope for but it will do the job mate.
  7. Scott_Hol
    Scott_Hol Member
    584
    Had a look on their site. . . turns out they do
  8. Syvo
    Syvo IF IN DOUBT GO FLAT OUT
    1,338
    22
    megs tar remover they sell which is good stuff and its smells of coconuts :)
  9. Lee_R
    Lee_R Active Member
    2,499
    12
    Autosmart tardis is the best but its impossible to get hold of in normal shops as its a trade product.
    I just use cellulose thinnners, be careful and its great! I've also used WD40 in the past, suprisingly good and getting it off too.
  10. dc240969
    dc240969 Member VCDS Map User
    925
    White spirit does the job.
  11. DaveyB
    DaveyB No misfires.
    269
    I'd go with the Megs if I were you chap :ermm:
  12. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,132
    1,971
    This is the one recommended by detailers/polished bliss
    Good gear
  13. Jimmeh
    Jimmeh Active Member
    1,438
    As above, Scott. AS Tardis is the one to go for if you can.
    AS Tardis - Autosmart Tardis - Tar & Glue Remover - 5 litres - Elite Car Care
    Obviously though you probably wont be wanting a whole 5ltrs to yourself.. Perhaps contact some local friends who want to go halves?! A chemical sprayhead and a bottle each and then you're laughing!
    Example. Ford Mondeo ST200.
    Alternatively, then yeah, Halfords do a few themslves; Autoglym tar and glue and then the above mentioned Megs tar remover
  14. tdia4
    tdia4 TDIPOWARRR
    613
    Tardis all the way, nothing else comes close, autoglym's tar remover is ok, but megs tar remover I think is one of the worst on the market.
