Tapping noise, worse when engine warm
TTJess Sep 7, 2012
  1. TTJess
    TTJess New Member
    I've got a 2007 2.0tfsi FWD TT, engine code BWA.
    Bought it 6 days ago, its got an annoying tapping noise from the engine, also when sat on idle, it's very lumpy, but revs don't move.
    Been told the tapping could be the cam chain tensioner, that the tapping will be worse when oil is warm, and that it will only be lumpy when warm, which are the symptoms of my car but the garage said there are no problems what so ever. The issue with it being lumpy is getting worse each day.
    Highly annoying, but anyone got any clues to what it could be?
    Thanks !
  2. dzTT
    dzTT Active Member
    333
    29
    I'm assuming youve bought it from a garage. Take it back to them as they should have to fix it. Did you test drive before you bought it?
    I also have no idea what you mean by lumpy lol
  3. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,487
    I've always thought the 2.0T was tappety.
    Your 'lumpy' idle may be cured by a change of plugs, but it's hard to say without seeing it.
    As said above I'd take it back and get it checked ASAP.
  4. TTJess
    TTJess New Member
    I've took it back and they are claiming nothing is wrong with it, but the idle only does it when it's warm.
    Yeh i did test drive it, but i probably didn't hear the tapping because it had a belt squeak, which they sorted before i picked it up, along with the handrake. The idle was not at fault when i test drove it.
  5. audicruiser
    audicruiser Audi Heaven
    1,865
    Well I have the same engine in mine and it smooth whether it's cold or warm... It does sound tappety, that's the way they are. It's the injectors that make the racket! It should be lumpy though and if it's only doing it since they sorted a belt squeak then it must be linked. Maybe the belt is over tensioned...
  6. warren_S5
    7,210
    2,487
    Do knackered tumble flaps 'tick'?
  7. snapon
    snapon Member
    37
    Get the Car scanned with VCDS this should reveal stored fault codes relating to your idling problem and go back to the twat with a printout
