taking engine out
superkarl Mar 27, 2013
  1. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    Currently i dont have an engine crane to take the old one out.
    So becuase il be acting as the crane, im undoing the gearbox from the block, and lifting the block out alone.
    Just taken 4 of the bolts i can see underneath from the gearbox.
    How many are there?
    And does anyone see a flaw in my plan?
    If i had a crane id be taking it all out as one. This way is a little better on my back.
    Im contemplating unbolting the transfer box and NS driveshaft and removing the block and gearbox together.
    Id just like some input as ive bit decided yet.
  2. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    are you hercules???
    Can you not borrow a crane of someone? who make the job soo much easier. you'd still have your disks in the right place after aswell
    JonBoi25 likes this.
  3. cecilthesausage
    cecilthesausage ...It's Never Finished...
    933
    Can you not hire one locally Karl and take it all out in a oner.....?
  4. Dani_B19
    9,382
    403
    How much weight can you lift karl? Haha.
  5. Blackcupraa
    Blackcupraa Member Team Ibis VCDS Map User Audi S3 Manual
    193
    15
    Hire a crane, if it's just you doing it, you will be in A&E.
    I tried to lift a 2.2 Honda engine from a Prelude with a friend, i'm quite well built and we couldn't lift it at all. Remember, when you do lift the engine the car's height will be increased at the front due to you removing the engine. Which makes your job twice as hard.
  6. superkarl
    9,610
    2,481
    You lot think im stupid dont you.
    Dani, i can deadlift twice my body weight fairly easily
    il look into hiring a crane.
    Ive a pd130 engine sat here, whilst its heavy, and entirely cast iron, i can move it about. so i figured a 1.8t block would be a piece of ****.
    So how many votes for all in one on a crane??
    How many for try and seperate block and lift it with my wang?
  7. Paradox1
    1,833
    88
    Karl you nutter!
    why are you even taken the engine out?
  8. s3jon92
    s3jon92 Member
    32
  9. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    The gym he lifts at has no weights left, therefore SuperKarl goes on in search of heavy objects to lift..
  10. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,165
    1,124
    That's fine but your about 4'11" and weight 8 stone.
    Remove the front end of the car.
    Put a jack under the engine and box, lift it up off the engine mounts and slowly move the engine out the front of the car while its on the jack.
    Or how ever it works for a 1.8T.
    I've done it like that on a BMWs and Sierras with out much issue.
    Its a lot easier and safe than trying to lift it up and out of the bay, its not like lifting your steroid laced protein shake out of the sink.
  11. Reesy
    3,640
    148
    Remove front end of car, which takes minutes, leave fmic, crash bar and lights etc attached to slam panel so that saves a job at the other end.. After you've undone all the necessary ancillaries, rest the engine and box on a jack as you undo the mounts and then, with the crane you have borrowed, move the engine out the way.
  12. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Stop drinking Skol, and listening to "youl never walk alone" and get the front end off.... ;)
  13. superkarl
    9,610
    2,481
    Scott, im 5 11 and weigh 13 stone.
    And just resting the whole engine and gearbox on a jack isnt going to *** work you pleb.
  14. Scullies
    Scullies Well-Known Member
    1,543
    658
    You wont be dead lifting it because of the angle, go to gym now, put the weight in front of you and try lift it. you also have to video this and post it here so we can complete our voting.
    The complete block is heavy and you going to pull a fat lifting it :lmfao:
    Also if you drop it, the block or your feet might get slightly modified!
    I would recommend getting a crane lift or even a chain hoist if you have somewhere to anchor it to. Just remember to leave space so you can push the car out the way.
    so my vote goes, crane.
  15. ScottD3
    15,165
    1,124
    It will and it does you *** cock.
    I've done it more times than you removed an engine by the looks of it.
  16. coatesy
    coatesy poking badgers with spoons
    1,920
    280
    That's cute but your only a baby...
    If you are dead cert on doing what your saying take the head off then the sump off then take the box out then the block. Bit by bit if you get me.
    No way will you be able to lift the engine out over the top.
    Or you could drop the engine and lift the car over it.
    Or even better pull the front end off like everyone else would and pull the engine out
  17. superkarl
    9,610
    2,481
    The front is off!
  18. coatesy
    1,920
    280
    Now Take your pants off... Upload photos :D
  19. ScottD3
    15,165
    1,124
    So take the engine out that way.
    What's your problem?
  20. Scullies
    1,543
    658
    Have you thought how you going to put it all back in the car?
  21. ScottD3
    15,165
    1,124
    He'll just lay on his back, using 1 arm to hold it in place and the other arm to tighten the bolts up on the engine mounts.
    azman likes this.
  22. vroomtshh
    vroomtshh Active Member
    362
    49
    I've lifted the PD160 out of my car more times than I care to count. All the people making a fuss clearly haven;t tried it.
    Just so you know though, a 1.8t is mildly heavier than the PD130 you've been lifting
  23. Essflee
    Essflee Well-Known Member
    2,154
    67
    Lmfao !!!
  24. smurfworth
    smurfworth Well-Known Member Audi S3
    1,954
    548
    Drive to your local park maybe? Im sure the council wouldn't mind..
  25. superkarl
    9,610
    2,481
    The pds block and head are cast iron. My 1.8t has an alloy head, which is off and wasnt very heavy.
    Im going home now anyway
    This saga continues tomoro
  26. s3dave
    10,110
    736
    He has got oil on his shell suit... :)
  27. superkarl
    9,610
    2,481
    Dave dont you have your weekly caravan club meeting??
  28. Blackcupraa
    193
    15
  29. James TQ
    James TQ Member
    561
    wear wrist straps and a weight belt : ) when you deadlift its even weight on each end and a straight bar, and engine i expect has bad grip points and maybe off centre balance? cant you jack the car up and drop it out underneith?
  30. superkarl
    9,610
    2,481
    Il get it out, and il photograph it all.
    I started on the gearbox seperation anyway, i just wanted to know how easy that would be in the bay.
    Meanwhile ive been taking downpipe out, removing turbo lines and undoing various power steering and coolant pipes etc.
    Im on ny bill 99% of the time. Could do with turning the car around in the garage really.
  31. Gops
    3,198
    666
    Ah go for it. Did it on my fiesta. Just take out the front end and use a jack to pull it out. I made a makeshift trolley and popped it on there, then wheeled it out the bay. They don't call you super Karl for no reason!
  32. Jason.s
    Jason.s Active Member
    2,879
    348
    If i could maneuver a 200kg Jag XF engine inside a delivery cage onto the back of a loading ramp on a truck you can remove a block from a 1.8t. Go do work son! Take pics with overalls half way up, topless and covered with oil holding a big wrench for the masses while you`re at it! Make sure you`re really angry. Strength is doubled and pain is reduced.
  33. James TQ
    James TQ Member
    561
    ^^^ youl have to wait for the callender for that one...
  34. Scullies
    1,543
    658
    Ok, unsubscribing from this one before the pictures get put up and I :puke2:
  35. Prawn
    11,676
    3,673
    Scott is right, jack under the middle and front off and it'll pull out with no crane easily.
    Also, for the more sideways thinking among us, if you don't fancy balancing the whole lump on a single jack, you could always lift the engine up one side at a time and put it on blocks, then push the car backwards.
    Definitely don't need a crane for a 1.8T though, so easy to remove /refit.
  36. s33nyboy12
    s33nyboy12 Well-Known Member Audi RS5 Owners Group Navarra Blue Classic
    1,496
    212
    Karl you are a legend mate! I can't stop laughing at this.
    Jokes aside , I reckon with a bit of grunting and groaning you could do it. I've done it with a 1.6 esi civic engine and a Mondeo st24 engine. I was a keeno at the gym at the time :)
    sean
  37. ScottD3
    15,165
    1,124
    Did that with a MK1 escort.
    Was unable to remove the front we had to lift the whole front end up and wheel it backwards.
    Kind of wished we left the rear axle on.
  38. Westy
    Westy Well-Known Member
    17,443
    1,105
    Just get a bloody crane you plum ;)
    I like as little hassle as possible, you seem to love hassle.
  39. badger5
    9,603
    2,061
    easy way<< >> hard way............... guess which is chosen
  40. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,297
    373
    Hard way = well earned man points for pub talk later on
