Tailgate won't lock Avant tqs
bhainart Feb 13, 2011
  1. bhainart
    bhainart New Member
    25
    Evening all,
    Just bought an Avant tqs and when I went to lock the car up on key fob all doors lock fine but when I checked the tailgate was locked pulled the tailgate open....obviously not locked. Tried a couple of times but would still not lock. The lock is in the horizontal position and the two key fobs that came with the car do not fit the lock. Waiting to hear back from the guy who I bought it off about key for lock but thought some of you guys may have ideas.
    Should the tailgate lock from the key fob as I assume it should or am I missing something?
    Thanks in advance
  2. hades-
    9,481
    646
    they all lock from fob
    sounds like the lock is broke
  3. bhainart
    bhainart New Member
    25
    Cheers for that. Sort of confirms my initial thoughts....
  4. aragorn
    18,174
    770
    The lock barrel just siezes up, give it some penetrating fluid??
    As for locking, facelift cars have solenoid actuated boot latches, do you hear the solenoid do its thing when you pull the handle?
  5. bhainart
    bhainart New Member
    25
    Aragorn, thanks for the reply.
    I can't hear a solenoid activate but when I shut the tailgate it needs a bit of a tug to open but I can pull the tailgate open. The tailgate doesn't fly open when driving so it's obviously catching on something lockwise but it just won't lock. Does it matter that the lock barrel key slot is in the horizontal position or should it just lock normally with the keyfob regardless of the position of the key slot?
    Going away to Aviemore in two weeks with a car load of stuff and worried about the tailgate opening on the M6...lol
    Thanks in advance
  6. aragorn
    18,174
    770
    What i'm saying is it doesnt actually have a lock.
    The button to open it fires an electronic solenoid to pop the lid, and the control unit simply disables the button when the car is locked.
    With mine, you press the pads to open the tailgate (or the button on the remote) and theres a "zzzt" noise as the solenoid fires, and the boot pops up a tiny bit. You can then lift it open. If yours isnt doing this i suspect the solenoid is jammed. If it IS making the noise, but you can open it by simply pulling it (rather than pressing the pads), then presumably the solenoid isnt releasing properly?
    If the solenoid is firing with the tailgate closed and the car locked, theres something up with the central locking control unit.
  7. bhainart
    bhainart New Member
    25
    Thanks for that fella. Will take a better look when it stops pissing it down
