Tail light Retrofit - Parking Light
Matuh Apr 24, 2014
  1. Matuh
    Matuh Member
    49
    Hi! yesterday i install the Led tail lights and when i active the parking light, only de inner works, and in my moms car 8P 2012 the inner and the outer works.
    It is possible to active the 2 lights??
    Thanks!!
  2. Artimus
    Artimus Shortback
    2,016
    485
    Hi mate!
    In Europe the inner are Fog Lamps! The outer are the brake lights! I believe there's an option to switch them in VCDS. I'm sure someone else will be able to point you to the correct page.
  3. Matuh
    Matuh Member
    49
    Hi!
    The inner have the fog and the reverse lamp, thats OK, but the led dont work when i put the packing light, if i need to put a new code and works it will be great!!
    Thanks!
  4. Matuh
    Matuh Member
    49
    Nobody??
  5. Artimus
    Artimus Shortback
    2,016
    485
    Hang on, I'll get the code for my setup
  6. Artimus
    Artimus Shortback
    2,016
    485
    This is all in the Central Electronics Module\Coding\Long Coding Helper! All references to the Rear lights are highlighted in Red & the selections are my settings:
    There are also some "back up setting" which I didn't include. Hope this helps, Good Luck
  7. Matuh
    Matuh Member
    49
    Thanks veryyy muchh!!!!!!
    Later i connect the vagcom a try it!!
  8. Matuh
    Matuh Member
    49
    This config is from a A3 facelift ?? My car in pre facelift, but i found this,
    Audi A3 Rear Fog Lights
    But this use fog light as taillight, and the LED tail light have light and fog light with diferents bulbs
  9. Matuh
    Matuh Member
    49
    I think it is no possible in mi car (Pre facelift)
    The only way i think it works is use the same wire that use the outer taillight, it is a little crazy :D
  10. Artimus
    Artimus Shortback
    2,016
    485
    Did you use a new loom when you installed the units?
