T SPORT STALLING PROBLEM
dans3.0 Mar 10, 2010
  1. dans3.0
    dans3.0 Member
    56
    Hi all,
    Just popped over from the B6 side to ask some advice for my son
    He has an 1998 1.8T Sport Auto and just recently it has just started to stall immediatelly after start up, not every time but now and again.
    Any ideas what could cause this
    Dan
  2. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Hello mate, there a literally 20+ threads about the illustrious stalling problem on this forum...Do a search and you will find a shed load! It could be a number of things, immob , TB , N80, wiring (Geemans recent prob), split breather pipes, clogged breather pipes etc etc etc...........
  3. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    3,992
    759
    As stated above, do you have or know anyone with vag-com, also does the immob light come on after it stalls?
  4. aragorn
    18,579
    868
    immo is the first thing to look at, it will usually mean the immo light flashes after it stalls though.
  5. Geeman
    Geeman Low Life
    1,318
    Wiring was a problem on mine. The immediate stalling happened on mine after I'd sorted the wiring out though... and it was the actual connectors themselves not having a good solid grab on the MAF terminals. Closed them up tighter and now it's fine.
  6. dans3.0
    dans3.0 Member
    56
    Thanks all,
    He says the Immo light dosn't come on, he's going to clean maf etc check wiring and go from there,
    its not done it since so will have to wait n see.
    Dan
