  1. jojo
    28,993
    3,638
    Silly question really, but what's the take on T-cutting paint from the professional detailer's point of view?
  2. 1210tech
    1210tech Four Ring Fanatic Team Daytona Team V6 Audi A6 Audi Avant Owner Group S-line owners group
    696
    it's ****! you won't remove any swirls/scratches and will most likely put more in. you might remove oxidisation and give a bit of life to the paint but thats about it
    what result/work are trying to acheive/do?
  3. jojo
    28,993
    3,638
    I was just asking out of curiosity. :icon_thumright:
  4. stan
    stan Member
    136
    I've had great success with t cut but only on CDs that are scratched, repaired manys CDs DVDs with this stuff.
  5. Mr OCD
    Mr OCD Obsessive Car Detailer
    50
    I am a pro detailer ...
    T-cut doesnt contain diminishing abrasive therefore will put in just as much scratching as you try to remove with it... it also contains ammonia and can discolour single stage paint ...
    T-cut got left behind in the 70's... there are MUCH better alternatives these days to use. :tocktock:
  6. WX51TXR
    WX51TXR Polished Bliss
    1,452
    14
    As above... in many cases it seems to do more harm than good for the reasons offered above... and there are now many more polishes out there that do a significantly better job, whether by hand or machine. My advice is leave it on the shelf and instead use a set of modern polishes with finely milled diminishing abrasives that are suited to hard germanic paints; the Menzerna range is probably the best currently available in these respects. :)
  7. abdus
    abdus Top Gear VCDS Map User
    1,827
    any recommendation then from the pros?
  8. 1210tech
    696
    as rich said above, the menzerna range, either PO106FA or probably PO85RD3.02 are gonna be your best bet on vag paint but by hand its gonna be a complete bitch and take you days rather than hours. your gonna need to use, at the very least, a random orbital polisher such as a porter cable with a medium to hard polishing pad to remove any paint defects.
    go here and have a browse: http://www.detailingworld.co.uk/
  9. WX51TXR
    1,452
    14
    If you choose to work by hand, you've little chance or removing anything more serious than minor marring, so often the best bet is to use a glaze like Menzerna Finishing Touch Glaze or Blackfire Gloss Enhancing Polish to fill and hide any defects, and then seal the finish with a decent wax or sealant (to boost the gloss and lock in the fillers). However, if you really want to attempt some degree of correction by hand, and have arms like Popeye, then Menzerna Intensive Polish applied using the white side of a German Pad will yield some improvement, and will break down properly to leave a decent finish (even if defects still persist). However, if you are happy to consider buying a machine polisher, then you will be able to make much more headway in terms of correction... :)
  10. abdus
    1,827
    Thanks...so best bet would be a polisher then...
    any good polisher below £50?
    lol..can't afford more than that atm due to baby on the way in 5 weeks...
  11. marms
    marms Member
    833
    With all the things you 'have to have' for a new baby these days you will have some electrical gadget that will be useful for applying polishes.
    Couldn't you adapt one of these?
    Good luck with with your new arrival when he or she arrives.
  12. abdus
    1,827
  13. marms
    marms Member
    833
    The problem with the two you have listed is that they are not random orbital and , unless you know what you are doing, you could easily burn the paint on your car because of heat build up. The random orbital versions are much easier for a novice to use and, unless you are particularly careless, almost impossible to do any damage.
    I'm not sure either of those would be a great purchase unless you are well practiced and know what you're doing.
  14. Clark@Polishedbliss
    Clark@Polishedbliss Professional Detailer
    226
    Wise words :)
    If money is an issue regarding purchasing a machine polisher, maybe keep an eye on Ebay for a 2nd hand PC (Porter Cable) but even then it wont be as cheap as £50 i'm afraid. Maybe just save a bit untill you can afford one or a new Meguiars G220, at least by then the warmer and dryer weather will be here :icon_thumright:
  15. abdus
    1,827
    so a UDM model 1000 would be good enough for a start?
  16. abdus
    1,827
  17. abdus
    1,827
  18. marms
    marms Member
    833
  19. abdus
    1,827
    yeah, looking for 2nd-hand transformer from a friend. Just need to buy the plug.
    Better invest in something worthwhile and save a respray job with a **** polisher...lol
    Just above budget :huh:
  20. marms
    marms Member
    833
    Abdus,
    I replied to your PM so I think you have everything covered now.
    Good luck and don't forget to post the picturess of your efforts when the car has had a once over :)
  21. abdus
    1,827
    Cheers Mike...will post when used and satisfied with the results. :)
  22. WX51TXR
    1,452
    14
  23. abdus
    1,827
