Symphony stereo
vwgtiking Jun 23, 2013
  1. vwgtiking
    vwgtiking Active Member
    1,030
    I got these 4 keys off eBay and for the life me I cannot remove this good damn stereo. It's the double din with cd changer built in. Any advice? Or are the keys just ****?
  2. Audi Doodah
    Audi Doodah Active Member
    377
    35
    So that's why you want the glovebox out! :laugh:
  3. vwgtiking
    1,030
    Cos once I got stereo out I was gonna run iPod wires into glove box for new stereo like I did with the golf.
  4. vwgtiking
    1,030
    No that not why. Lol
  5. Audi Doodah
    377
    35
    I was thinking you can push on the back of the headunit when the glovebox is out...
  6. vwgtiking
    1,030
    Really ok
  7. Audi Doodah
    377
    35
    Unless you have hands like shovels, you should be able to apply some force to the back of it. Just make sure the keys make a positive click when inserted IIRC
  8. vwgtiking
    1,030
    Ok glove box out. Phase 2
  9. hades-
    9,481
    646
    get better keys ?
  10. vwgtiking
    1,030
    Romeo done!! It's out.
  11. vwgtiking
    1,030
    Phase 3. No power to new hu. Is the wiring different ie power and ground. Like the golf?
  12. hades-
    9,481
    646
    what HU are you fitting ?
  13. vwgtiking
    1,030
    Pioneer avh p4200 dvd
  14. hades-
    9,481
    646
    did you get the correct wireing ?
    you also have to run a igg feed to the new HU
  15. vwgtiking
    1,030
    Ignition feed? Wtf this is turning into a joke?
  16. vwgtiking
    1,030
    Oh I see only 2 connectors line up.
  17. vwgtiking
    1,030
    Any wiring diagrams?
  18. vwgtiking
    1,030
    I can pull the male connectors out but I don't know the wires are the Audi???
  19. vwgtiking
    1,030
    Anyone?!?
  20. Audi Doodah
    377
    35
  21. vwgtiking
    1,030
    How would I know if mine is Bose?
  22. vwgtiking
    1,030
    How do I get I to work with constant power on?
  23. Audi Doodah
    377
    35
    Your door speakers will have the Bose logo and the headunit says Bose when it first powers on.
  24. Audi Doodah
    377
    35
    Look what I found with a quick SEARCH
    quattrojames likes this.
  25. Audi Doodah
    377
    35
    And if all you wanted was an ipod hookup, these are plug and play with factory headunits
  26. vwgtiking
    1,030
    Ive connected the yellow and red wires together on headunit and still. I power
  27. vwgtiking
    1,030
    Still no pwr*
  28. Audi Doodah
    377
    35
    Do you have a multimeter? Test for correct voltage on the wires? Has the fuse blown on the car? Has the fuse blown on the headunit? Have you ever seen your new headunit working?
  29. vwgtiking
    1,030
    Found the issue. The acc cable on the headunit has a resistor and this didn't give the headunit enough power to start up. Swapped it over and it works. Next job is to wire in an ignition wire and get the rear speakers working.
  30. vwgtiking
    1,030
    With regards to this the 3rd connector the one furthest to the left. What are these connections for? Do I need the com and arrow with a dot middle???
  31. Audi Doodah
    377
    35
    You rear speakers aren't working because they're driven by an amp in the boot, via the line outs, I believe.
    There is plenty of info out there as you're not the first to fit an aftermarket headunit.
    http://www.audi-sport.net/vb/car-entertainment/3187-rear-speakers-not-working.html
    http://www.audi-sport.net/vb/a3-s3-...onnected-rear-speakers-still-not-working.html
    How to install an aftermarket radio without a wiring harness - AudiWorld Forums
    http://www.audi-sport.net/vb/a3-s3-sportback-8p-chassis/76733-help-aftermarket-stereo-replace-concert.html
    It took me 2 minutes to find the links. I would suggest you spend some time reading up before continuing.
