Symphony II to II+ upgrades
s8craig Nov 7, 2007
  1. s8craig
    1,754
    56
    Anyone interested in upgrading their symphony II to a 2007 Symphony II+ with large display and Mp3 playback on the 6 CD changer with ID tags.
    I'm thinking around £199 fitted including manual etc.
    Craig
  2. Crisis
    Crisis Member
    93
    Does the unit play MP3 CDs then?
    I miss it alot!
  3. steve184
    steve184 Active Member
    1,138
    i wouldn't bother - II+ has some bugs over the older II - i prefered the old one
  4. emzino
    emzino Active Member
    1,231
    Yea I really want to change my Chorus because it's doing my nut in that it can't read MP3 CD's. Is there a Chorus 3? I don't need the tape player in Symphony =/
  5. s8craig
    1,754
    56
    Lets just be clear here, the symphony II+ is the latest generation CD/radio from Audi for 2007. It has a 3 band radio and 6 CD changer player with MP3 capability. NO TAPE DECK.
    There is a concert II+ single CD which is the same size as the symphony II+
    No Chorus radio.
    Here is a link to the symphony II+ radio.
    http://clipboard.servepics.com:8081/Pictures/Symphony/symphonyII+.jpg
  6. centurion
    centurion 3rd gear's my favourite...
    Yep I'm interested... but I have a single din concert unit at present, can it be done?
    Cheers...
  7. s8craig
    1,754
    56
    It is possible, but obviously there is more cost involved.
    Conversion from single to double DIN is tricky in the A3 but not impossible.
    Another £199 for the conversion
  8. centurion
    Cheers s8craig,
    400 sheets, that might have to wait a while and plus I don't know when I'm gonna be in Manchester unless you fancy a trip down here to the south west?
  9. dai-click
    dai-click New Member
    9
    I'm interested as I have a Symphony II and would like MP3 playback. If its a simple plug-n-play I could fit myself, unless it needs VAG COM. Do you have a price to send to West Wales for a DIYer??
  10. s8craig
    1,754
    56
    It can be a simple plug and play, I can supply the cables and a set of keys but I would have to charge for postage, next day.
    If you specify the spec of your car I will make sure the symphony II+ is programmed up to your specs.
    Craig
  11. dai-click
    9
    s8craig - you have PM
  12. s8craig
    1,754
    56
    I have read your PM I think we may have an issue, if you have CD based nav in the boot with the controls by the hand break I think you cannot have symphony II+. From 2007 the BNS5.0 was the solution for CD based nav.
    So the symphony II+ does not have the inputs required for the nav system voice commands.
    I have checked in Elsawin and the the BNS 4.0 that you have will only work with the older symphony/concert II.
    Craig
  13. dai-click
    9
    OK thanks for that we will have to forget it. How doeas the fact that I have the CD based Sat Nav effect the swap to the DVD RNS-E Sat Nav unit should I wish to go that route?
    Dave
  14. HeliChris
    HeliChris Learning to fly 3D
    195
    Be carefull, one member tried it and failed because the aerial system had changed. Also if you play MP3 cd's as advised by the manual, Audi won't warranty it when it goes wrong. (my experiance)
    Chris.
  15. s8craig
    1,754
    56
    I know of the antenna issues and have resolved this.
    Why Audi will not warranty a CD changer designed to play Mp3's after playing Mp3's CD's is beyond me, I would sue there 4rs3s off if they tried to pull a stunt like that.
  16. s8craig
    1,754
    56
    As long as you disconnect everything you will be fine.
  17. mattandrew
    mattandrew Member
    977
    21
    Sorry to hijack this thread I am wanting to do something similar, I have an A3 8P 2004 with the single din unit with the CD based nav in the boot with the controls by the hand break and the full bose system. I want to swap this for the RNS-E based DVD sat nat.
    I presume I would just disconnect the controls in the centre. What would you charge to do this s8craig (single to double din, RNS-E, aerial conversions etc etc)
    I have read you can trim down the air con controls but need new esp switches and blanks.
  18. s8craig
    1,754
    56
    If you supply the RNS-E then I charge £300 for the whole conversion, switches, new facia, din cage and heater control move. And I will install the RNS-E, but if you need adaptor cables (which most people do) I will provide them at cost.
  19. JohnS3
    JohnS3 Active Member
    3,032
    Hi Craig, I know this involves a rewire for the antenna components in the boot lid. But can you tell me which components need to be changed if any?
    Many thanks.
  20. mattandrew
    mattandrew Member
    977
    21
    Craig
    what would the adapter leads cost?
    Which would i need, aerial and antenna etc?
  21. s8craig
    1,754
    56
    About £40
  22. JohnS3
    3,032
    OR how much would you charge to do the work on my behalf?
  23. s8craig
    1,754
    56
    John
    What were talking about here is the older ZF/HF to 2x HF, not the RNS-E issue with your car.
    Craig
  24. JohnS3
    3,032
    Thanks for the clarification.
  25. TheBoyes
    TheBoyes New Member
    Hi Craig
    Just a quick note to say thanks.
    Old man called me up to say he picked up the new radio this morning.
    Will let you know how I get on installing it when he brings it down in a couple of weeks.
    Rick
  26. s8craig
    1,754
    56
    No problems Rick
    Enjoy
  27. emzino
    1,231
    So all in all Craig, basically £400 to get a conversion from Chorus II > Symphony II+ right. Does that include fitting?
    Also, you know some new units complement the speakers better, am I likely to get bette sound quality from the Symphony II+ than my current Chorus II?
  28. s8craig
    1,754
    56
    The price is correct, I can't really comment on the sound of the Symphony II+ against the Chorus unit as I've never tested them.
    But the last guy I did Concert II to Symphony II+ for said the sound had improved.
