Symphony II advice required please
LiveWire Jul 6, 2011
  1. LiveWire
    LiveWire S3X
    329
    Hi all,
    I have just bought a Symphony II HU from ebay to fit to my car, before I receive it I want to find out if I can get a cable so I can use my Iphone to play music through it?
    Also my car has the Bose set up and has 2 sets of RCA leads which will need to be connected to the HU, will the Symphony II HU have ports on the back for the RCA leads? or will they run off from the loom at the back of the HU??
    Lastly! When I fit the HU how simple is it to code it so it shows the Bose greeting when turned on? I have access to vagcom.
    Thanks in advance for any advice :beerchug:
  2. s8craig
    1,750
    55
    2x phonos? is that 4 in total? never seen that on an Audi before. Surely some sort of hacking been done for a non standard unit. I would guess that you would need to reconnect these to a 20 pin mini ISO for the line outs of the Symphony II. Symphony II will have the pin outs on the lid so you can make the right connections, but you may need the right conncectors.
  3. LiveWire
    LiveWire S3X
    329
    Well when I removed the aftermarket HU there were 3 sets of phonos behind!!
    1 set were not in use that run to the back of the car, 1 set are connected to the sub out on the HU, and the other set are wired into the loom in the back of the aftermarket HU!!! I will get some photos up tomorrow, and hopefully someone can point me in the right direction.
    One thing I have just found out is the Symphony II is not going to play MP3 CD's!! :sob: one day I will learn to do my reasearch before I buy things :wacko:
  4. s8craig
    1,750
    55
    II+ plays mp3 CD's but not available for your chassis, it would have to be an A4 unit modified.
  5. LiveWire
    LiveWire S3X
    329
    Looking on the bright side, I will now have to buy a XCarlink so I can use my Iphone :drag: (far to many copied CD's in my collection)
    Are there any cheaper alternatives to the XCarlink?
  6. AndyMac
    9,832
    45
    Connects2 is the cheapest option at around £30
    If you have RCA's on the Audi loom you need to fish around behind the HU and disconnect the adapter as no stock Audi wiring uses RCA's
  7. LiveWire
    LiveWire S3X
    329
    O-dear received the Symphony 2 today, fitted it and had "Error 3" whilst trying to load a CD, I can hear the CD mech trying to work but it wont accept a CD :sob:
    Sent a message to the seller but had no response as yet :motz:
    Can I do anything in the mean time to try and fix the error??
    **I have just found this stereo on Ebay, (from the USA but seems a good price for a new unit) would it fit my car? it says it is for a A4 but looks exactly the same as the A3 unit**
    Audi A4 Bose Symphony II Radio/Cassette/CD#8E0035195A on eBay (end time 04-Aug-11 03:29:05 BST)
  8. s8craig
    1,750
    55
    My understanding is that the sym II is country specific, and possibly the AM/FM tuning increments will be incorrect. The II+ can be programmed for any country.
    So it may not work correctly.
    I have an A4 Sym II here you can have for a good price, perfectly working with code.
  9. twofivenine
    twofivenine Member
    62
    sorry to hijack...I've just bought a B6 S4, and the car has the symphony II head unit in. Volume button is broke, will adjust the volume but the push on/off function doesnt work. If you pull the plastic button off, you can do it with the metal part, it looks like the plastic button has broken - any one know where I can get a replacement button? I dont want to buy a new H/U when I can just get a button!
