Symphony 3 with multifunction steering wheel
Detector May 25, 2007
  1. Detector
    Detector Just waiting for the green light
    131
    If anyone has this exact specification could they check to see which functions do what the owners manual say, so far I can only find volume control is correct, please PM me if you would.
    Forget phone prep part !
  2. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    the right wheel does volume up\down. the left wheel does track up\down or radio station up\down depending on whether you are using cd or radio.
    the other buttons do nothing unless you have the phone prep installed. if you do then the mode button changes from radio to cd to phone. the right button is for the voice menus.
  3. Detector
    131
    OK then, then right roller is correct, the left however should change either CD tracks up for next track, down for last or in radio mode up for next programmed chanel 1-6 or down for last programmed channel.
    Is this the same in yours or is it reversed ?
  4. jamiekip
    jamiekip Guest
    The left button will also let you fast forward/scan through a track - push and hold the roller button.
  5. JohnS3
    JohnS3 Active Member
    3,032
    Mmmmm, my mode button just goes from radio or CD back to phone prep again.
  6. Vertigo1
    Vertigo1 Well-Known Member
    3,387
    547
    yes that's right, Marc was getting a bit confused I think - it won't switch between CD and radio, just switched between the current audio source display on the DIS and the phonebook.
