Symphony 2 to Symphony 2+ Help
Rom Mar 23, 2013
  1. Rom
    Rom Member VCDS Map User
    443
    Looking to charge these units over for a friend.
    Its a 2005 A3 with the Symphony 2 6 cd headunit.
    Want to fit the 2+, had bought some adapters, but still doesnt work. Gets some inital cd mech sounds, then nothing.
    Straight off, i can see loom and old unit has 2 pins on black iso plug, new unit has 3.
    Heres some pics to explain better...
    Old unit
    New Unit
    Car Loom
  2. NHN
    29,331
    1,716
    The newer 2+ units need an extra 12v supply to pin D16 mate on the quadlock fella, so link 15 & 16 together, don't forget antenna system will be different.
  3. Rom
    443
    Cheers mate. Hoped it would be something simple.
    Not looked, but assume the plug is labelled like usual?
    He has the aerial adaptor, think it was double fakra of the top of my head.
  4. s8craig
    1,750
    55
    You have to join the two fakra HF connections of the new radio to the existing ISO HF connector, do not connect the fakra ZF connector at all. If you don't the antenna will cut out. So you need a sort of Y adaptor from the radio to the antenna.
  5. Rom
    443
    ZF and HF ?
  6. micon12
    micon12 New Member
    also having issues with the unit. NHN do you have to add in an extra wire myself or can i pull one out from one of the other plugs and put it into another plug?
    Thank you
  7. NHN
    29,331
    1,716
    Just follow what my post advised.
