Switching Air Bag from Current Steering Wheel to a New MFSW - Possible?
MB RS3 Jan 19, 2013
  1. MB RS3
    MB RS3 Member
    170
    Hi All,
    Current Steering Wheel is a bog standard Audi S3 "Round Wheel" with an airbag but no controls.
    I'm looking at getting this:
    OEM AUDI S3 8P Sport Steering wheel - BKS-Tuning
    Which doesn't have an airbag so is it possible to switch my current airbag into this?
    If so is it relatively easy?
    If not where would i get an airbag from (Audi Dealership) & how much roughly are they?
    Thanks for you help in advance people! :icon_thumright:
  2. hades-
    9,481
    646
    it wont fit
    ebay or dealers for the round bag
    they go for around £200/250 on the bay
    a lot more at dealers you will also need the airbag loom and maybe swcm for the multifunction.
  3. MB RS3
    MB RS3 Member
    170
    Cheers for the reply mate. Is the best bet trying to find one with a bag then?
    £200/250 for the bag on it's own is that?!
  4. hades-
    9,481
    646
  5. mike foster
    3,967
    No mfsw will work unless you have the correct steering module - 8P0 953 549 F
    No other will do and neither will the 1K0 version F
  6. JayT
    JayT New Member
    27
    Does that apply to all 8P1s, 2s and 3s?
  7. mike foster
    3,967
    Yes !
    EDIT : I think some later 8P3's may have steering module version 'K' .
  8. JayT
    JayT New Member
    27
    How late are we talking? Like MY10/11+? Also are the K modules backwards compatible with older 8Ps?
    They seem to be a bit cheaper than the F modules so I was wondering if I could fit one to my MY09 8P3. :uhm:
  9. MB RS3
    MB RS3 Member
    170
    Ok cheers for that mate.
    So what do i need for the swap?
    The MFSW, AirBag & Steering Module - 8P0 953 549 F?
    Thanks Again!
  10. mike foster
    3,967
    MFSW with matching airbag. airbag wiring harness and steering module.
  11. MB RS3
    MB RS3 Member
    170
    Airbag wiring harness... How much are these roughly? Any specific part number or anything for them.
    Cheers!
  12. mike foster
    3,967
    Part number 8P0 971 589 AC approx £30 from Audi.
    Just to repeat this is not for FBMFSW
  13. mike foster
    3,967
    As far as I can ascertain you can use version 'K' ok in your car. Bear in mind it must be 8P0 NOT 1K0 module
  14. MB RS3
    MB RS3 Member
    170
  15. mike foster
    3,967
    Did you read my post - I said not for fbmfsw which is what that is !! However, if you buy that airbag the wiring loom is with it.
    It's the bit with the yellow multi-pin plug on it.
  16. MB RS3
    MB RS3 Member
    170
    Sorry, i don't know what you mean by "fb" mfsw (sorry for my lack of knowledge on the subject ha)
    Ok so I'm guessing the wiring loom is the "harness" you said it may require?
    If i buy the MFSW & That Bag - All i would require would be the 8P0 953 549 F Steering Module? Is that right?
  17. mike foster
    3,967
    That wheel is 'Flat-Bottom' which is the FB in FBmfsw !
    Yes, if you buy those three items that is all you need but you are looking at £600 +
    Then you need coding with VCDS.
    EDIT: just checked the part number for the airbag in that ebay ad - it does not exist !! That is the part number for the wiring harness but will have suffix letter/s as well.
    Ask seller for the airbag part number and I will check it. Also ask for the wheel part number.
  18. MB RS3
    MB RS3 Member
    170
    Haha! My bad! It's obvious after hearing what it means!
    I'm guessing the steering module is fairly pricey then?
  19. mike foster
    3,967
    I have edited my previous post - please read !
    Yes the module will be about £100 on ebay and £200 from Audi !!!
  20. MB RS3
    MB RS3 Member
    170
    PM'd you mate!
  21. MB RS3
    MB RS3 Member
    170
    Hi mate,
    Wheel Part No: 8P0 419 091 CR
    Airbag: No sticker.
    Look forward to hearing from you,
    Cheers!
  22. mike foster
    3,967
    Sounds right - will check in a bit !
    MB RS3 likes this.
  23. MB RS3
    MB RS3 Member
    170
    Ok mate!
    Seller also advised airbag fits wheel, wouldn't surprise me if it is from the wheel & he is just splitting the sell as you said before!
  24. mike foster
    3,967
    That wheel /airbag is ok so all you need now is the control module and coding !!
    New, the wheel is £550 and the airbag is £760 !
    Try these for modules :- 8P0953549F | eBay
  25. MB RS3
    MB RS3 Member
    170
  26. mike foster
    3,967
  27. MB RS3
    MB RS3 Member
    170
    Quality Thanks for all your help bud!
    So that module has everything that's required prior to getting it coded with VCDS?
  28. mike foster
    3,967
    Correct !
  29. MB RS3
    MB RS3 Member
    170
    Thanks for your input mate.
    I've bought all 3 products, so all i need to do now is get it coded, just to double check it doesn't have to be an Audi dealership that does this does it?
  30. mike foster
    3,967
    No - check VCDS User map for owners in your area who will be pleased to help you.
    MB RS3 likes this.
  31. MB RS3
    MB RS3 Member
    170
    Just to double check i don't need a new "Slip Ring" aswell do i? (I don't have cruise control, i dont know if this has any bearing on fitting the FBMFSW or the Module i have to buy?
    Look forward to your reply mate!
  32. robbiedondo
    robbiedondo New Member VCDS Map User
    22
    Hi mate, I' m in Maidstone and can code for you if that helps
  33. MB RS3
    MB RS3 Member
    170
    Ok mate, give you the run down, i have these parts on the way, FBMFSW, Air bag to fit, & 8P0 953 549 F.
    Am i good to go for coding?
  34. Ash187
    7,469
    728
    yes those are all the parts you need, now just need to fit it and code it to your car.
    after coding you will need to do a 'steering angle reset' so make sure who ever is doing that for you knows what that is.
    also since you are changing over the steering module you may as well just get cruise installed as your taking off most of the bits that need to be taken off when doing a cruise install.
    I can do these coding/installs for you if you need? i am only by bluewater so not too far.
    also i know this is a little late to ask but have you got a manual or auto?
  35. MB RS3
    MB RS3 Member
    170
    Alright mate, its a manual, what parts would i need for cruise control?
    Thanks.
  36. Ash187
    7,469
    728
    just the cruise control stalk which replaces the indicator stalk and the lower cowling that has the cut out for the new stalk.
    if your interested pm me and i can sort out a complete price for you for the parts and fitting inc coding for the lot.
  37. MB RS3
    MB RS3 Member
    170
    PM'd you mate.
  38. mike foster
    3,967
    No - your existing slip ring is the correct one !
  39. mike foster
    3,967
    For anybody reading this thread the part number I quoted in post #12 for the airbag wiring harness is incorrect!!!
    It should read 8P0 971 589 AD. This number superseded suffix AB which in turn superseded Q !!
    Whether AD has now been replaced I don't know. !
  40. SJ
    SJ Member
    93
    "AD" is still the correct suffix, I ordered one last week when fitting a MFSW :)
