Switches and/or Buttons
ScottD3 Oct 20, 2011
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,162
    1,123
    I need a switch for my rear blind mod (http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/135158-rear-blind.html).
    I'd like a proper blind button from another Audi but I'm not sure if any other buttons will fit the B5 in the correct location.
    I got the facelift dash with front and rear fog light buttons. Not having front fogs is a bit of a bonus cause I can lose that button and fit something else.
    This is my current dash set up. I know the fog lights are in the wrong holes but I think it looks better. :)
    Does any one know of if the buttons from other audis will fit and match my current dash?
    And from them models do you know if they had electric rear blinds so I can rob that button off them?
    Thanks. :)
  2. Foxmeister
    Foxmeister Fired Up!
    1,785
  3. ScottD3
    15,162
    1,123
    I've read that post, how did I ever forget it.
    thinks mate.
  4. PaulJC84
    PaulJC84 Owner
    2,914
    17
    I have the funk one in mine - Can maybe see it in this pic?
  5. Foxmeister
    1,785
    ^^^ Flash mother funker!!!;)
  6. ScottD3
    15,162
    1,123
    what does funk do?
  7. PaulJC84
    PaulJC84 Owner
    2,914
    17
    When I press it the passenger gets ejected......it does nothing. I just bought it to replace the blank.
  8. Geeman
    Geeman Low Life
    1,318
    Scott... you managed to wire up the fogs okay?
    I've got a facelift console to put into mine, but holding back because of the fogs...
  9. ScottD3
    15,162
    1,123
    Not done them yet mate.
    I might attempt them this weekend after I finished the rear blind.
    Its going to be rough job till I do the heater matrix. I'll tidy it up then along with all the other cables.
    I got a wiring diagram for it if you want?
  10. Geeman
    Geeman Low Life
    1,318
    I've heard it's nigh-on impossible to do... especially if you haven't got the fog light control box (which I haven't) from behind the glove-box.
  11. ScottD3
    15,162
    1,123
    O, yeah it is. you need that box.
    I got some thankfully.
    Its because of the switch.
    Any facelift car should have one or just fit some normal on/off switch some where.
  12. Geeman
    Geeman Low Life
    1,318
    Might have to go back to the breaker (if it's still there) and rob it out. Would help if a) I knew where it was and b) I knew what it looked like!
  13. ScottD3
    15,162
    1,123
    Remvoe the glove box its there.
    and its a block box with 2 plugs in it.
    check some of the other posts by me in the B5 section. there is more info on it in there and an image.
  14. Geeman
    Geeman Low Life
    1,318
    Bugger. I removed the glovebox from the breaker already. Damn it. Should have swiped it... but didn't know I needed it.
    Will check your other posts dude. Cheers!
  15. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    Soupie, where can you get the "funk" switch? could do with on for a little project i have in mind :D
  16. Geeman
    Geeman Low Life
    1,318
    WTF is a 'funk' switch?
  17. AR-rkon
    1,913
    166
    :lmfao::lmfao::lmfao:
  18. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    its a button with 'funk' written on it (funk is german for radio)
    the button is used for taxi/emergency vehicals in germany
  19. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    i have a FUNK button also i wanted to connect it to the amp switch to turn the sub off still havent got round to it yet!
  20. Foxmeister
    1,785
    *Off topic*
    ^^^Ras, ive got that keyring, good taste mate!:icon_thumright:
  21. AR-rkon
    1,913
    166
    Anyone got a p/n? Ideally in the gloss black plastic rather than the lighter rubbery plastic?
  22. Foxmeister
    1,785
    Its in the post i linked to at the start of the thread......but seeing as im a nice guy, here you go Mr Techniker!;)
    [FONT=arial, geneva]Dash Switch (98-01) [4B0 969 903 B][/FONT]
  23. ScottD3
    15,162
    1,123
    what you planning?
  24. AR-rkon
    1,913
    166
    Wait and see :) build thread will be made as soon as I have collected all the parts ;) haha
  25. ScottD3
    15,162
    1,123
    with images please.
    still waiting on pics from your arm rest thread :moa:
  26. AR-rkon
    1,913
    166
    Ok ok smart ass. Didn't get a chance to take any pix. But it's coming out again to put some illumination in there, so will get some (and measurements) then.
  27. ScottD3
    15,162
    1,123
  28. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,721
    162
    Is the dash switch just a simple 12v on/off switch? (Not one of these 'node' switches that switches from 3.7v to 4.5v?)
    If its a normal 12v switch, then it would be easy to make your own loom with a relay (or two smaller ones) and wire it up that way?
    I made a 12v relay loom for some HID headlights on a Ford KA as the KA wouldn't power the Offside headlight everytime. Very easy to make up. And cheap too! Paid £1 for two relays and already had the wire and terminals.
  29. AR-rkon
    1,913
    166
    I meant the "Funk" switch :D not the rear blind haha
    **EDIT** found it: 8D0035775A
  30. ScottD3
    15,162
    1,123
  31. aragorn
    18,484
    855
    The switches are momentary switches. The relay box is just a pair of latching relays.
  32. Foxmeister
    1,785
    Ok ok, you crazy motherfunker!!!!:)
  33. AR-rkon
    1,913
    166
    and just what do you mean by that :aggressive:
    :lmfao: kiddin...
  34. S4_dan
    2,721
    162
    So it's either purchase latching relays or change the switch......
    Still relatively simple to build a loom/relay up.
    Dan
  35. aragorn
    18,484
    855
    The sensible thing to do is just get the proper relay box from the car the console comes from.
    Simple enough to wire it in then.
  36. ScottD3
    15,162
    1,123
    I got the switch from Audi for the my rear blind.
    One small issues, its a lefty, which is right where my fog light switch is.
    Does any one know if there is a right handed fog light switch to replace the blanking plate?
  37. aragorn
    18,484
    855
    isnt the left hand fog switch for the front fogs, and the middle one for the rears?
  38. ScottD3
    15,162
    1,123
    Yup.
    I can just remove it for now but I'd like to keep it if possible.
  39. olds_kool
    1,094
    15
    Is that an A6 switch, didn't think they fitted A4's
    Different slope angle to switch front
  40. ScottD3
    15,162
    1,123
    Its a A4 B6.
    I've not fitted it yet, I'll do it tonight and see what it looks like.
