Switched live
TURBOTRONICS Aug 5, 2011
  1. TURBOTRONICS
    TURBOTRONICS Member
    187
    Do i have an ignition switched live in the boot of my s4 avant
  2. scott b
    scott b Active Member VCDS Map User
    1,254
    i dont think so, there maybe a switch live when you turn the radio on (amp in boot)
    what is the ignition live needed for
    or you could run a wire from the fuse box to the rear
  3. TURBOTRONICS
    TURBOTRONICS Member
    187
    i wanted to set up a split charger in the boot
  4. scott b
    1,254
    can sort you out a split charge relay, works of a live feed then senses when the car is running, then when car is switched of it senses the voltages drop and shuts of, we use them on towbar wiring
  5. TURBOTRONICS
    TURBOTRONICS Member
    187
    sounds interesting how much are they
  6. scott b
    1,254
    will find out tomorrow and do it at cost to you, think they are around £8
