Switched Live?
chrisash32 Oct 14, 2010
  1. chrisash32
    chrisash32 Member
    573
    Anyone know where i can pull a popper switched live from in the A4?
    I did have one place where i thought there was a switched behind the glove box however this doesn't really time up with the ignition. It times with locking and unlocking of the car.
    Thoughts anyone?
    Cheers!
    Chris
  2. simon.m
    simon.m Active Member
    2,747
    the lighter is a good one i think or just find the ignition live mate think you can get this from the fuse box or from the ignition its self just put an inline fuse in if you do it that way though
  3. chrisash32
    chrisash32 Member
    573
    ok, i will have a go at the fuse box later and see.. i just have a vague feeling i had been there before with no such luck.
    Ideally i could do with it being in the boot....
    Cheers!
  4. simon.m
    2,747
    i think you may have to run your own into the boot mate im not 100% sure though you maybe lucky if its in the boot you need it id say pick it up from the lighter in the center consel and run it back under the carpet
  5. chrisash32
    chrisash32 Member
    573
    yeh. i thought so.
    I wondered if there was one of the amp wire for the sub but i think this might be linked to the stereo on/off rather than the car.
  6. simon.m
    2,747
    id think your right about the amp and id not want to cut into that my self
  7. quattrojames
    14,060
    583
    Doesn't your avant have a permanent live at the 12v socket in the boot Chris?
  8. chrisash32
    chrisash32 Member
    573
    Yeh, i have already tapped into that James for my fixed live feed, however I now need a switched live too :)
  9. BASS 666
    BASS 666 BMW aye right dead on..
    463
  10. quattrojames
    14,060
    583
    Ah sorry.
    * Note to self - read question!
  11. fourcircle
    fourcircle nj
    939
    29
    Fuse 5 is possibly switched live mate. I asked on another forum ages ago and will at some point need to check too if I put in an aftermarket HU
  12. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    there is a thin red wire in the steering colomn that is switch and stays on till you remove the key
  13. Nutkin
    Nutkin Member
    830
    this but use it with a relay or else oyu may fry your bcm.
  14. Garfie
    Garfie Member
    179
    I got mine from the fuse box, cant remember which fuse though.
    Front cig lighter socket is permanently live
  15. WILLTHARE7
    WILLTHARE7 New Member
    17
    ok ill go for the fusebox. another question lol sorry i have a aftermarket reversing camera on the cable with video input there is a small red wire coming out of each end what are they for lol
    cheers
