Swirl marks.
s3clarke Dec 8, 2012
  1. s3clarke
    s3clarke Money grabbing s3!
    677
    35
    What's best to get rid of light swirl marks in dark paint, without a buffer?
  2. Gizmo68
    Gizmo68 VCDS & VCP owner in Kent VCDS Map User
    88
    Without a machine polisher you want something like AutoGlym Super Resin Polish (SRP) as it contains ‘fillers’ which will mask the swirls, this doesn’t last forever though, the only way to fully remove them is by a machine polisher.
  3. DickosS3
    DickosS3 Member
    30
    ^1
  4. s3clarke
    677
    35
    Cheers pal.
  5. DickosS3
    DickosS3 Member
    30
    Get urself a machine polisher pal. Well worth the money. Start with a da. Ull be suprised with the results.
  6. Gizmo68
    88
  7. WAFTER
    WAFTER Member
    281
    19
    Removing swirls with a machine polisher takes practice to achieve the skills required. Why bother when a professional will do it for you. Having peace of mind and somebody else doing the work and having the responsibility is worth the few bob spent.
    Followed up with a good hard protective finish will minimise repeating the process too often.
    s3clarke likes this.
  8. matts1
    matts1 Member
    71
    22
    as said, will be difficult without a machine polisher. I tend to use Poors boys Black hole glaze as it is designed for darker cars and is really easy to use, followed up with nattys past wax, again, easy to use and designed for darker colour cars. I found these also didn't show up stone chips like some polishes.
    Gourlay1990 and s3clarke like this.
  9. the_cueball
    the_cueball Active Member
    496
    218
    43
    There are some polishes out now that work well by hand to remove light swirls... Gtechniq P1 for example...
    It may be a bit harder because Audi paint is 'generally' considered hard, but worth a shot...
    :thumb:
  10. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,320
    768
    +1 here for Poorboys blackhole, finished mine off with collinite to seal it. Still looking good after 2 months of being kept outside.
  11. s3clarke
    677
    35
    Thanks guys, the poor boys is defiantly on the cards after xmas. had my eyes on it before. I used auto glym SRP then dodo juice purple haze on it the other day. the shine is lovely, but there is a few swirls in the paint. I'm probably being a bit over the top, but would like the paintwork as good as I can get it, then if i'm still not happy my pal machine polishes cars pretty cheap.
  12. sidibear
    2,320
    768
    The only problem is that when you do start and get rid of the swirl marks you tend to get really anal about the finish as any swirls you have missed will stand out more, and drive you nuts until you sort them. It will totally transform the finish of your car though.
