Sweeping Dials through VCDS?
SamiG Feb 8, 2011
  1. SamiG
    SamiG On Boost, ish.
    233
    Playing around with VagCom earlier and set my doors to auto lock above 15kph and unlock on key removal.
    Also set the 'beep' when i lock my doors :drool:
    I want to know if it's possible to set 'sweeping dials' when you start the car. So when you put the ignition on all the dials sweep to the right and then reset again. Not sure if it's possible on the 8L but if someone could confirm?
    Also another mod through VCDS i'm trying to do is to set the front indicators to come on permanently with the headlights to give a constant Amber glow...
    If anyone could help me out it would be much appreciated :thumbsup:
    pangsterA3 likes this.
  2. ptr
    ptr Member
    128
  3. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    You can make the dials do a full sweep by doing an output test in the instrument module but dont think you can make it do it every time you start the car.
    How did you make the alarm beep, would like to do this myself.
  4. 1animal1
    9,978
    the early S3 8P boys want this too but the only way to do it i beleive is by fitting an S3 8P3 instrument cluster, which means your pretty much buggered im afraid
  5. Westy
    Westy Well-Known Member
    17,443
    1,103
  6. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    linky dead matey. I can upload it tonight if anybody wants it.
  7. Westy
    17,443
    1,103
    oops, cheers for spotting that. I have a copy of the tool too.
  8. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    I'll be interested in the file, if its any good for A4 B5s.
  9. Westy
    17,443
    1,103
  10. pangsterA3
    pangsterA3 Member
    143
    how did you do the auto lock and alarm beep mod??? :)
  11. Westy
    17,443
    1,103
    The easiest way is to use the little tool talked about above called Base Code. Do a search for it on the net because the link above is dead.
