Sway bar bolt
Ironborn Aug 6, 2013
  1. Ironborn
    Ironborn English...not so good
    1,179
    227
    I'm trying to take off the suspension and as always with this car nothing is ever simple. I have removed everything except the sway bar bolt. I can't seem to remove it. The minute I unloosened it ,It just spins around when you turn it and doesn't seem to tighten or unloosen anymore. I know you hold it standy with torx but it's too tight the torx ends up slipping. Anyone who has removed the suspension any tips?
  2. NHN
    29,353
    1,720
    Its not a torx its a spline, so you've probably buggered that now.
  3. Ironborn
    1,179
    227
    I have a spline kit and none would fit.
  4. NHN
    29,353
    1,720
    Well mine did, problem is I had to cut one of before as the fixing was buggered, you are putting spline etc in the end to hold the thread steady & then undoing the nut with spanner, iirc.
  5. Ironborn
    1,179
    227
    Yeah that's right, but with mine a CR-V5 is too small and CR-V6 is too big. Is there possibly a middle spline I'm missing? 40 torx seems to fit nicely but I can't get a strong enough grip to counteract the spanner. I'm happy that I've managed to do the rears though.
  6. eddyd
    eddyd Member
    99
    Vice grips on the ball joint and try not to nip the rubber boot, or else a hacksaw!
    (you may have to unscrew one end to get access to the other
  7. Ironborn
    1,179
    227
    Do you think vice grips will get a strong grip?
  8. bmh.01
    bmh.01 Member
    291
    17
    They're **** just cut them off and get new ones for afterwards. They've even tight as hell brand new so no surprises they aren't overly forthcoming to remove after a while on the car. The spline on the ball just rounds off if they're really tight they aren't a good enough fixing.
    That said a good scrub up with a wire brush and a decent penetrating fluid does help a lot.
  9. mjr901
    mjr901 Guest
  10. mjr901
    mjr901 Guest
    here's mine I took off.
    heres the size too.
  11. Ironborn
    1,179
    227
    Thanks for so much for responses; much appreciated. I may have bitten off more than I can chew. It would be a shame now to take it to garage after having bought spring compressor, strut spreader and few other things.
    Question 1: I’ve never cut of a bolt before, what’s the best tool. A saw might take some serious elbow grease.
    Question 2: Where would I cut from, there’s minimum space behind the seized bolt.
    Question 3: mjr901 are these the bolts?
    M10 X 55mm SETSCREW BOLT HIGH TENSILE STEEL WASHER NUTS 5 PACK | eBay
  12. mjr901
    mjr901 Guest
    Q3: Yeah man that's ideal. :)
    Edit** sorry it's M10 x 70mm.
    Ironborn likes this.
  13. mjr901
    mjr901 Guest
    wait it's M10 x70mm. sorry mate, don't buy the ones in that link!!
  14. Ironborn
    1,179
    227
  15. mjr901
    mjr901 Guest
    Get ones that have a full thread up to the hex top to be sure, as they have a smooth sleeve on the ones you have shown.
    +2 washers per bolt.
  16. Ironborn
    1,179
    227
  17. mjr901
    mjr901 Guest
