Swapping Audi Concert for Symphony or Multimedia
V8Guzzler Mar 6, 2011
  1. V8Guzzler
    V8Guzzler Active Member
    583
    26
    Does anybody know, if this is possible or in fact actually done it?
    Car currently has aftermarket headunit installed (due to concert developing volume knob fault) - would it be fairly straight forward to replace with Symphony or MM unit?
    Cheers:s4addict:
  2. Cabbyfan
    Cabbyfan Active Member
    840
    34
    If you want to get rid of a single din to accomodate a double din symphony 2 or RNS-E its fairly easy, the longest bit if the DIN cage swap. Been loads of threads on here about RNS-E installs, should tell you everything you need to know. Personally I hate seeing Audi's with non standard sound, especially Pioneer things with lots of flashing lights ewwwwwwwwwwww
  3. V8Guzzler
    583
    26
    ok great - where would the best place to find a double din cage?
  4. a4 cabrio
    a4 cabrio Member
    135
  5. V8Guzzler
    583
    26
    Yeah, just been looking at that.. it says A3 though... will it fit a 2003 S4 does anyone know?
  6. blucoop
    blucoop Member
    85
    they're 45 notes delivered from audi !!!
  7. a4 cabrio
    a4 cabrio Member
    135
    says it will fit a4's also
  8. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
  9. V8Guzzler
    583
    26
    Thanks all... ill keep looking.. think i will just go for the Symphony.. RNS may prove too challenging :)
  10. a4 cabrio
    a4 cabrio Member
    135
    ok, i was goin by what the guy put in the ad, he said fits a4 as well. was trying to help, maybe i shouldnt have unless i was sure
  11. Cabbyfan
    840
    34
    Actually the RNS-E is really easy, pre-assembled wiring loom (Bose or non-Bose), stick the GPS antenna somewhere metalic and Bobs your Uncle, the long winded bit is the double din conversion.
  12. V8Guzzler
    583
    26
    ok great, I have also heard that a new HVAC is needed or you have to cut the existing one down??
  13. Cabbyfan
    840
    34
    I bought a new climate controller when I did mine but yes you can cut the existing one down if you are good at that kind of thing.
  14. V8Guzzler
    583
    26
    Ok I have picked a up and S4 with Symphony 2.. So is the change to RNS - E fairly straight forward as it's double din?
  15. paulsb
    paulsb Member
    138
    yes, all you need to do is remove the synphony 2, plug in the harness, plug in the ariel lead and gps. takes about 5 minutes if you have double din.
    everything worked on mine without being programed as well.
  16. C17LJR
    C17LJR Member VCDS Map User
    513
    have a look on ebay or kufatec,
    you need a plug & play kit to swap these units, the kits have the iso adapter, diversity adapter, gps antenna & removal keys.
  17. V8Guzzler
    583
    26
    Sorted, thanks all - I will be giving this a go then :)
