Swapped Delta CC HU with CONCERT from 98 A4
king84 Apr 6, 2012
  1. king84
    king84 Spartacus
    10
    So I swapped my old Delta CC HU with a CONCERT from 98 A4. Started it up and everything worked just fine with the radio. The only issue is my 6 CD changer won't play and when I put in an iCarPlay cassette adapter the amp doesn't the rear speakers. Any thoughts.
  2. king84
    king84 Spartacus
    10
    I guess I should of researched it before posting anything. No CDC was the code received. Programming is next step in order to make my Head Unit recognized the changer.
  3. aragorn
    18,538
    865
    AFAIK Deltas had all four speakers amplified by the headunit, whereas concerts only amp the front speakers and had a small standalone amp in the rear to drive the rear speakers.
    I also have a feeling the CD changer is electrically different, and you'll need a concert CD changer.
  4. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,164
    1,123
    Thats what I was going to say.
    Get some VCDS on it. :)
  5. king84
    king84 Spartacus
    10
    So apparently nothing can communicate with the Concert HU. It may have to deal with the fact that it may have been tweaked by the last owner to not require a security code even if it was disconnected for long periods of time. So instead of going through the trouble of another concert, "Operation 1 Din to 2" is on. Symphony radio is in transit via UPS. Picked up the frame three days ago to support everything. All that is left is the face trim with boot, arm rest, and AC unit.
