swap dis and cc from 1.9 to 2.5????????
vorsprung dork Feb 17, 2011
  1. vorsprung dork
    vorsprung dork Member
    256
    i have a 2.5 tdi sport and a 1.9 tdi se! se has dis and cc the 2.5 does not is it possible to swap these parts from one to the other and if so can anyboby do this cause this one is over my head!
  2. hades-
    9,480
    646
    you will need to recode the clocks for immobiliser to work
    stupid question from me is the 2.5 a v6 ?
    if it is a v6 the clocks may not work not sure on diesels sumat to do with the rev counter
    i know on the petrol the v6 clocks wont work on say 1.8 2,0
  3. vorsprung dork
    256
    yeah 2.5 tdi 1.9 tdi be nice if i could swap as these are wasted on the wife! she cant even use the cc! dont know why i married the useless mare! oh sorry i do coz she told me i had too!
  4. vorsprung dork
    256
    oh yeah! thre both on an 04 plate if this helps!
  5. swarcup
    swarcup Well-Known Member
    1,326
    40
    yes iff they are both avants or saloons, as the dis stalk on the avant pushes back for the rear wiper. Recode clocks? you will need vagcom to deal with the coding for the abs, steering angle sensor and turning on the cruise and dis. recoding clocks is only needed for a cluster change i believe
  6. vorsprung dork
    256
    oh no! avant and saloon! arse! no cheap fix on this one then! forgot about the small matter of the leaky sub standard rear wiper carry on! ********!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  7. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,170
    150
    You only need to fit the DIS stalk and code the instruments to accept it. Then DIS works.
    Cruise Needs the stalk and maybe a new control module, vagcom coding and all good.
  8. benjie
    benjie Well-Known Member
    1,223
    304
    The clocks are definitely interchangeable - I have 2004 V6 clocks in my 2003 1.9TDI.
    Not sure about all the stalks etc, it gets complicated!
  9. adamss24
    adamss24 Well-Known Member
    4,557
    394
    Yeah, as above, you just need to tell the clocks they're fitted to a 4 pot or a 6 pot engine but you need the SKC (secure key code)!
  10. hades-
    9,480
    646
    wish it was that easy on a petrol i have 2 seys of RS4 an 1 S4
    with colour DIS
