suspension or wheels?????
evzee Jul 19, 2010
  1. evzee
    evzee Member
    35
    Hi guys and girls. Only been a member for a week or so. I've done nothing but search, read. Serach some more, read a bit more. I'm still pretty confused on some stuff. I aint got a clue what to do first. I'm raising some funds (around £250-£350) to do my first little mod to my audi. I bought it a few weeks ago. Its 99 2.4 v6. totally stock. Now, do I slap some wheels on it. Some nice 18 or 19's. That'll be it for a year til I can raise some more cash. Or is it gonna look daft? I might be able to get some alloy seconds and some lowering springs, but springs on stock shocks doesn't seem to be rated that much.....? Or do I get some coilovers and run stock alloys for year? I'm not really into hitting the audi on the deck. Maybe lose an inch or so. The standard sport look is enough for me. Input people, I need some more input. Your gonna have to talk to me like a kid, it took me blimming days to find out what billy b8's were! haha. Thanks
  2. evzee
    evzee Member
    35
    ....and while I'm on a rant. Is it me or do we b5 owners get bum'd when it comes to getting parts? quite a few bits and pieces i've come across seem to be cheaper for b6 and a shed load more for b5. I found b6 coilovers from belgium £119, same ones for b5 add another hundred quid! same bloody part. Someone tell me b6 shocks and springs will fit our b5?
  3. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    cheap coilovers for adjustable ride height and looks but teeth shattering ride
    or shock/spring combo for lowered and decent ride/handling.
    suspension and handling over wheels in my opinion.
  4. S4twiggy
    S4twiggy Fully Certified Detailer!!
    1,815
    9
    suspension first mate defo
  5. Oranoco
    Oranoco Well-Known Member
    3,834
    363
    Suspension first mate, transforms the car, I run AP coilovers which are a budget kit with good results, Will need to hike your budget a little though as they seem to go for about £450 at the moment
  6. evzee
    evzee Member
    35
    cheers chaps, that sounds good enough to me
  7. aragorn
    18,036
    725
    Personally, i'd do the suspension, but on that budget i wouldnt fit a shock/spring kit or coilovers.
    I'd replace all the front arms (with good Meyle or Lemforder parts), the rear axle bushes and then fit some half decent 40mm lowering springs.
    You can absolutely guarantee that will make the car feel and drive better than fitting coilovers or spending $£$£ on a shock and spring kit, becuase no matter how good the springs and dampers are, if the suspension links are flopping about under it all, its going to drive like a bag of ****. A mild 40mm drop will be fine on the standard dampers, and will at least give you some visual difference for your hard earned.
    The biggest single change i made to our old FWD was changing the rear axle bushes. Cost £14, and the difference was so pronounced you could feel it from the passenger seat.
    Meyle front arm kits are on german ebay for about £330, you'll get some generic 40mm lowering springs on ebay for about £60quid, and the rear bushes can be had from All German Parts for about £15.
  8. jcb
    4,132
    13
    [cough] polybush the lot [cough] ; )
  9. Oranoco
    3,834
    363
    Have to say I recently changed mine and the improvement was huge. Even the lady (who knows not much when it comes to cars) said it felt a lot more composed.
  10. evzee
    evzee Member
    35
    thanks to ALL you guys.suspension is clearly the way forward. I'm goin with aragorn on this one, it seems to suit my budget. I'll be ordering the parts this week. I know im gonna need spring compressors but is there any other tools or bits thst might not be in your average toolbox? I can get hold of trolley jack and axle stands. Will i need anything else for these new suspension arms and springs?
  11. aragorn
    18,036
    725
    The front arms are bolt on. You will need a balljoint splitter for the lower arms though.
    The pinch bolt on the top two arms is a known issue (it gets stuck/siezed). I'd get some plusgas and apply it to the bolt lots over the week or two before you do the work. The meyle kit i mentioned has all new bolts with it, which is useful.
    The rear bushes are a bit trickier. I did mine using some threaded bar, and some tube, plus some metal plates to draw them out.
  12. martinA4passat
    martinA4passat New Member
    26
    Hi, I fitted a Koni shock and spring package at the weekend, I fitted the fronts without removing any of the ball joints top or bottom, if you search on google there are instuctions available. If you have not done this before take your time and dont start Sunday morning if you need the car for work on Monday! The pinch bolt that holds the two top arms on is a bugger and you will spend a few hours trying to get this off.
    I Fitted Koni Street shocks and springs, The shocks have lifetime cover and lowers the car by 35mm, rides well and not back breaking. not bad price either, half the price of coilovers. Would recomend these. I will post some before and after picks tomorrow when she is washed and waxed!
  13. aragorn
    18,036
    725
    If hes doing the arms the pinch bolt needs to come out!
  14. voteforpedro
    voteforpedro Member
    632
    Suspension first, definitely. You could spend £3k on wheels but they would look **** at stock ride height. Whereas even standard wheels with a slight drop look the balls.
  15. martinA4passat
    26
    I was just referring to the shocks and springs, I think it's obvious he would need to undo the pinch bolt to remove the arms :)
  16. jamie226bhp
    jamie226bhp Member
    468
    How much was the kit as i was looking at this and saw it on a forum for about £280 but i can't remember where and was worried about the ride quality, don't think it would lower mine much as it's a sport which i think is already 20mm lower
  17. aragorn
    18,036
    725
    Euro performance dont list any Koni STRT kits for quattros, so it might not be available for your car at all...
  18. jamie226bhp
    jamie226bhp Member
    468
    Typical I'll end up having to spend £500 instead of £300
  19. Fraser
    Fraser Member
    584
    sell the 2.4 and buy a 1.8T or 2.8 or S4
    more fun!
  20. evzee
    evzee Member
    35
    the 2.4 was cheaper to insure by a mile. On paper there really isn't alot between any of the v6 models. I did myself a favour by not getting a turbo model. Theres way too many options and goodies for them. I'm family man, so i went with the "sensible" option. Hasn't stopped me from thinking of some serious plans for the future....... Biturbo 2.4......hmmm.......
