Suspected gearbox problem - 1.6 tiptronic
katsumoto Mar 25, 2008
  1. katsumoto
    katsumoto Member
    52
    Hi all,
    Wondering if you could help out. I am wondering is my gearbox has a problem. Here's why:
    - when I change gears from P to D, relatively quickly, there's delay in engagement and a clunk sound when engaging (didn't happen with any of my previous cars), or if I change from R to D, same thing. If I change slowly, it seems to engage a lot quieter but still a slight delay
    - when I am driving on the highway, in 6th gear, and accelerate quickly after slowing down, there's a jerk from the gears changing (6th to 4th), this hasn't only happened once. I've noticed it happening more often now and wondering what's going on.
    I've reading other articles that some of those symptoms mean it's a bad gearbox and needs to be fixed etc. :keule:
    Anyone heard or experienced these things?
    Thanks in advance.
  2. katsumoto
    katsumoto Member
    52
    Anyone?:uhm:
  3. katsumoto
    katsumoto Member
    52
    Anyone?:uhm:
  4. Amchlolor
    Amchlolor Active Member
    5,604
    'Clunking' was part and parcel of my DSG (now called s-tronic) experience.
    Hard to comment on yours specifically though.
  5. katsumoto
    katsumoto Member
    52
    Thanks Bowfer, I am hoping that nothing's wrong, my car's only got 24000km's on the clock!
    From my experience, no other car has done this. This is my first "tiptronic" though.
    Even with that in mind, I am sure it can't be any different from a normal auto tranny.
    Does anyone have experience of fault codes showing up when there's something wrong with the gearbox?
  6. Amchlolor
    5,604
    The way it's built and works is vastly different from a normal auto box.
    I became convinced, quite early on, that my DSG was strange.
    However, driving other DSG cars proved it wasn't.
    You will, at some point, get some 'clunking', simple as that.
    I used to get occasional clunking when changing from 2nd to 3rd.
    I used to get clunking when trying to pull away on a steep hill.
    I used to get clunking when going from reverse to forward.
    When I say 'clunking' I mean some quite unpleasant driveline shunt, occasionally accompanied with a loud(ish) bang.
    Unpleasant enough for passengers to go "ouch", or make comment about my driving, when all I was doing was pressing the bloody throttle!
    DSG did, sometimes, make you look like a learner with poor clutch control.:keule:
    Not all the time though.
    If yours is doing it all the time, get it checked.
    If it's only occasional, I'd say you're fine.:whistle2:
  7. katsumoto
    katsumoto Member
    52
    From the things that you have described, my experiences seem pretty similar. Good to hear that someone has had similar "problems". I'll keep my eyes and ears open for any further "developments". Let's hope it's all nothing but paranoia!
    Thanks for the info Bowfer!:arco:
  8. Amchlolor
    5,604
    Ssssh, you're not allowed to call them 'problems' on here.
    It's you not adapting your driving properly.;)
    I'll get me coat.:undwech:
  9. katsumoto
    katsumoto Member
    52
    haha, right on! that's exactly what the stealers would say! it's your fault, not ours!:no:
  10. dbm
    dbm Active Member
    650
    191
    43
    I've had issues with my DSG in the past, which may or may not have been caused by my driving style, but ultimately needed a new ECU to fix (done under warranty at 55k miles).
    As Bowfer says, DSG is a totally different type of 'box to a traditional auto. DSG has two clutches whilst regular autos have no clutch but a torque converter instead.
    The 'Audi approved' way to drive the DSG seems to be to have it in some kind of gear (D,S or Tiptronic) pretty much all the time, except when you are stationary and want to take your foot of the brake. If you stick to that approach it should snatch a lot less...
    Cheers,
    Dan
  11. Amchlolor
    5,604
    Sorry, but I don't follow the above.
    How else are you going to drive it, unless it's in D,S or tiptronic?:uhm:
  12. dbm
    dbm Active Member
    650
    191
    43
    I used to knock the box into N when cruising to a stop at lights for example, and would flick between N and D if I was in stop-start traffic. Both of these behaviors seemed to exacerbate the problem.
    Cheers,
    Dan
  13. katsumoto
    katsumoto Member
    52
    hmm, I guess I drive the Audi approved way then. I used to think (my old car) by setting it to N while cruising would save gas, until I read that it actually doesn't because the engine then has to use more gas to keep it running....gotta try find that article again
    But also, mines not a DSG, it's a tiptronic....any differences?
  14. Amchlolor
    5,604
    Oh, I assumed you meant S-tronic, which was called DSG.
    I think tiptronic is different.:uhm:
    God knows.
    DSG, s-tronic,tiptronic,technotronic,pump up the jam, pump it up.:thrashi:
  15. katsumoto
    katsumoto Member
    52
    cheers to that! all the labels and probably the only differences are the colors of the cables....:rock:
  16. Twizzler
    Twizzler Active Member
    490
    37
    Yeh, a bit like fridges and cookers really - they both use electricity, so they're probably much the same......
