suspected gearbox letting go (again)
FranA3 Mar 19, 2012
  1. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,216
    305
    hi folks well over the last few days when driving my car the gears are getting a little crunchy (technical term that is lol) and tonight i opened my bonnet to find my engine bay around by the battery covered in oil (think it gearbox oil) its not dripping wet soaked in it but you can tell there is oil there , it looks like its coming from where the passenger side drive shaft goes into the gearbox are the seals easy to replace ?? , is it a sign of my gearbox about to blow AGAIN need advice a.s.a.p as last time it cost a friggin fortune to fix resulting in a second hand gearbox being used
    cheers me dears
    fran :( :(
    . ps im most upset about my OCD clean engine bay getting dirty lol
  2. marknjayne
    marknjayne Member
    425
    sounds like its just a seal,not too expensive if so
  3. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,483
    Sorry to hear that Fran, sound expensive.
    Hard to say without seeing it, but if you get it to a specialist they'll be able to give you a better diagnosis.
    Are you hearing any grinding from the box?
  4. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    25,708
    8,790
    Hope its not to bad a problem Fran.
  5. FranA3
    7,216
    305
    I've got fingers toe's legs and everything else crossed its just a seal thats gone , no warren its drives all fine not a single noise only as i put it in gear its a tad notchy/crunchy and said oil over the engine bay , cost me over £650 to get it done last time and that was a second hand box too :(
    edit : also the clutch seams all ok the clutch point is the same and is not slipping at all , the clutch was replaced about 25k ago
  6. FranA3
    7,216
    305
    so do i sandra if it is a problem then its good bye to my new wheels i want to get :(
  7. Sandra
    25,708
    8,790
    Have you not got a show this weekend Fran?
  8. FranA3
    7,216
    305
    no not going to any shows till april now can't afford to go to loads yet lol
  9. Sandra
    25,708
    8,790
    Hope its just a seal thats away Fran. Got my fingers crossed for you. :) x
  10. FranA3
    7,216
    305
    i hope its just that , will get the jet wash in my engine bay tomorrow to see if i can see where its coming from i think
  11. SteG40
    SteG40 New Member
    If it's gearbox oil you should be able to tell because it stinks, really horrible smell. It could be a CV boot thats gone and sprayed grease everywhere that was my first thought anyway. Alot easier and cheeper to fix too.
  12. FranA3
    7,216
    305
    yeah I'm going to investigate more tomorrow , if it is the cv boot thats gone what could be causing the crunching gears lol
  13. Paullie
    Paullie Banana Menace! VCDS Map User
    2,076
    288
    Aww Fran, hope it's nothing bad wrong with your car :(. I've got everything crossed for you that it's a simple and cheap fix. Never rains Sweetie, does it? (((HUGS))) :wub: xx
  14. FranA3
    7,216
    305
    i know i hope its not again i was without a car for nearly a month last time trying to save up to have it fixed lol , i hope its a cheap fix because i want my new wheels if i have to spend a lot of money getting it fixed then i won't be able to buy any wheels and that would suck ass big time lol , oh no it certainly doesn't paulie it bloody pours in my world haha
  15. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    £5 for the seal under an hour to do.
    get it done very soon or bearings will need doing in the box like mine :(
    FranA3 likes this.
  16. FranA3
    7,216
    305
    went out and put out the rubbish so grabbed a few picys at the same time to see if it makes more sense to you all lol
    as you can see this is after a few hours at home [​IMG]
  17. FranA3
    7,216
    305
    take a look at the few picys I've just posted did yours look like that mate ??
  18. FranA3
    7,216
    305
    ok the car is going into the garage to be looked at one friday really hope its the diff seal , i jet washed the underside of the car today and it does look like its coming from there
  19. tdi-man
    1,783
    64
    hi
    mine was leaking from the drive shaft gearbox oil seal. leak fixed but gearbox whines so will drop it of at some point and get new bearings fitted
  20. FranA3
    7,216
    305
    im 98% sure its the drive shaft seal , thanks mate will let you know how it gets on , hope you get yours sorted soon pain having problems with the car isn't it lol
  21. Greenday
    Greenday New Member
    Hoope I'm not hijacking this thread with my first post, but does anyone recognise the below issue??
    I have an oil leak from the gearbox of the wifes 2006 A3 2.0T Quattro.
    The oil is leaking from the end of a cylinder which can be seen through an inspection hatch in the wheel arch of the passenger front side.
    The plastic cover at the end seems to be slightly degraded and I'm not sure if the leak is at the perimiter of this cover or from the centre of it.
    See photo's
    Questions:
    What is this part called?
    What is behind the plastic cover?
    Might this be a simple plastic cover and associated seal change out?
    Is this more sinister?
    Any help whatsoever appreciated ​
    [​IMG] [​IMG] Reply With Quote
  22. FranA3
    7,216
    305
    its ok mate its gearbox related so its all good , not sure what that could be take it to a garage and see what they say it is
  23. tdi-man
    1,783
    64
    thats a seal whch is easy to replace had to do mine as was leaking dosnt take long theres bearings behind there.
    use special sealant when refitting new one.
