Sam_
Down under
Hey were you after a fluidampr? Here's a good price on one...
http://forums.vwvortex.com/showthread.php?t=6150659
Lol, i txt my dad you see and said i need a 12point 19mm socket. I prob should have said mansize too. Ill get another, this was a spare of his not part of his man tools he uses at work.
Not loctite no, hmmm, should prob do that!
yeh the maf came dude, thanks, i shouldve confirmed receipt with you.
Tis mansize.
I noticed on my old maf actually, the element in it was no more, whether this as fallen out with me chucking parts around i dont know. Do you know if i can use the one in the rs4 housing?? Part numbers are 1 digit out, and same number of pins and same design?
Thanks tuffty.
Does the temp sensor part just become redundant if used on our cars then?
I think i will exchange my old s3 one for a new one, start a fresh.
I have 2 RS4 housings spare just in case
i have half a downpipe bill, it goes as far as to clear the prop. So its purely to see the fitment and neccessary extention of that, as well as lambda and egt placement because as you know things are tight on the MC side.whys this engine coming out?
its only just gone in............. eh?
Not looked at an RS4 wiring diagram or plug but the S3 has 4 wires... I assume the RS4 would have 5 to accommodate for the air temp sensor... this would suggest its not used but as I said the response curves are likely to be different and therefore scaling out on the map...
I rescaled my S4 MAF and it worked ok but could have done with a session on the dyno with the emulator to dial in the part throttle/low load stuff as the fueling was a little iffy on the lower air speeds... my car when finished will be emulated from the get go this time round though and Bill has got pretty good at dialing these in now
...I may look at experimenting with flow straighteners too...
Think you may have me confused with someone else bill.
Ive no running or map issues, yet.
yea you did on facebook..
there are'nt any more superkarls are there?? lol
This is impossible, the world would implode with another superhero..
Never... He just doesnt care about updating it anymore as no one other than a select few are really bothered.
i try and forget i have it sometimes.
I could definitely learn from this advice!!!!
I feel the same about my S3 when it comes to sticking bits on, it's a chore, but it needs to be done! At least mine is still road worthy!
when your car has been off the road as long as mine you lose the love and it becomes a chore
Lose interest in this baby and you will get a group falcon punch...FACT..when your car has been off the road as long as mine you lose the love and it becomes a chore, so its easy for me to forget about and concentrate on other things.
i used to always be thinking, gotta do this/that, order this, measure that, take things here and there. now i just take it as it comes when i have a spare few hours, hence why its taken so long
