Yu getting puffs of blue spoke mate? Mines being doing this since start of the summer and its not got any worse, my mechanic thinks its the piston rings too as the turbo seems healthy.
ferrari f430, did you not hear?But were you still able to beat a fiesta when firing on 3 cylinders?
dont forget its never been mapped.
Id rather check it somehow. An inline pump was on the cards anyway
im not going to replace an intank based on a hunch. id rather there was a way to test it first.No point in an inline if the one in the tank is screwed. Get that sorted first mate.
i suppose when its back up and running i can assess whether its up to the job then, and sort fueling from there
no evidence of det in the others no.Bit of bad luck mate
Possibly an injector failed? Was there any evidence of det in the other pots?
i've got a set of AGU pistons that i was putting in anyway mate but thanks.I'll have some agu pistons for sale soon so if you can find a cheap block you'll be sorted
how much it set you back?If its still on its original i`d replace it anyway regardless of it being ok or not. Seeing sooo many things popping on facebook recently from Bill and Niki when mapping about old tired fuel pumps causing top end to run lean and limiting what they can achieve. Hence why i changed mine 2 weeks ago with 124k on it.
