superkarls overhaul
superkarl Feb 18, 2011
  1. Dani_B19
    9,343
    394
    Thats me not using awesome for my 4 WA then.
  2. superkarl
    superkarl MAN OF STEEL
    9,571
    2,464
    im emailing the above info and pics. they can solve it. because im sick of it. i've trusted them reluctantly twice.
    all i wanted was the best most accurate alignment using modern laser machines, they fit the bill at the time.
    im unsure of my rights and what to expect tbh, i've never had a situation like this before
    any tips on how to go about this id be grateful
  3. Westy
    Westy Well-Known Member
    17,443
    1,105
    Mate you are not mr lucky right now! Unfortunately I have no idea what the settings are on my alignment or I'd share them with you. I went to my local VAG garage where they also race in a golf race series and just asked them to align it. The tyres that were on the S4 rims had perfect wear across all 4 of them and they'd been on the car for a year plus they weren't new when I got hold of them.
    I've only used Falkens once myself but as far as I could remember they tend to wear down a lot faster then most tyres but 3 months is ludicrous.
  4. superkarl
    9,571
    2,464
    i had a good road friendly setup in mind and i wrote it down when i took it them, they agreed it would be good.
    then left the toe like that and assured me it would be ok.
    parallel toe front and rear is what i want and what it SHOULD be!
    im waiting for dave to mention 'fkn trailing arm bushes' lol
  5. Dani_B19
    9,343
    394
    A jerry can and box of matches :).
  6. Westy
    17,443
    1,105
    What a waste of fuel :ninja:
  7. Dani_B19
    9,343
    394
    Haha, depends how you look at it mate.
  8. superkarl
    9,571
    2,464
    i've already wasted a tank going back and to!
    i cant contact them how id like, there is just an 'insert comment' box on their website, and thats it they'l get back to you.
    so i've asked for an e-mail address i can contact via my personal address.
  9. Westy
    17,443
    1,105
    You could try contacting them on here mate and see if it's any quicker.
  10. superkarl
    9,571
    2,464
    i got an automated response with some e-mail addresses i can contact.
    the ball is rolling....
  11. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Fkn trailing arm bushes....;)
    From your pisshead gypsy....:cool:
  12. superkarl
    9,571
    2,464
    no smoke anymore. all burnt away from the downpipe.
    source is still unknown, i have a close eye on the oil level.
    but all seems completely normal.
  13. Westy
    17,443
    1,105
    It must have been some kind of spillage from you removing the catch can you massive plum.
    AudiS3-Turbo likes this.
  14. superkarl
    9,571
    2,464
    pffft, maybe. who knows, i kinda hoped for something catastrophic so id have an excuse to rebuild the *****, ah well.
  15. superkarl
    9,571
    2,464
    so i've had a response from awesomegti.
    as expected there is various excuses and off topic statements regarding the cars components, the mileage, the way i drive etc.
    but what they dont seem to understand is that the tyre wear i've experienced is not normal, and is due to these rear toe in settings that they believe are 'minimal' and 'not out by much'
    i've responded accordingly, explaining how no matter how i was to drive in the 25mile commute i have, there is no circumstance that tyres should wear as such. and clearly, rear toe in is the cause. a setting i was assured is ok, and wouldnt cause said issues.
    bottom line, i am sick of buying tyres because of their poor service
  16. superkarl
    9,571
    2,464
    more e-mails have been exchanged.
    they seem convinced this is a hardware issue.
    with the vast amount of cars with poly bushes, AP coilovers, and s3daves tie bars, i cant see that being a possibility.
    they will look over my car at some point in the near future, il gladly let them check it for faults.
    they need to realise that .45 minutes above the specified max of toe in isnt right.
    its as simple as that in my eyes.
    and even if there was a hardware issue, this should have been highlighted suring the service and brought to my attention, because they should have realised there is a problem somewhere.
  17. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Good luck getting it sorted, try getting past the people on the first line desk, I've sorted issues with awesome by doing that. If all else fails then post on their Facebook wall, that soon gets their attention!
  18. superkarl
    9,571
    2,464
    cheers buddy.
    i've got their attention.
    its just a case of them realising whats wrong and why, followed by them sorting the problem.
  19. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,294
    372
    maximum total allowable toe of 0.4° and you have 1.7° and its not much out? ....... only 425% out i guess....not bad!?
    even more is you say that the total toe in should be about 0.25°, then its 680% out....
  20. superkarl
    9,571
    2,464
    according to them its not degrees, its minutes. but seeing as theres only 60 minutes in a revolution as opposed to 360 degrees, that makes it even worse!
  21. Alex C
    3,294
    372
    mmm so the min and max limits for total toe are from 0.1' to 0.4'? That is a tiny window - 0.3 minutes or 20 seconds, 20"
    Unless of course they mean 0°10' to 0°40', but then they have your final total toe as 1°70'?.. there are only 60 minutes in a degree so it should read 2°10'?
    also 85' (1°25') toe-in each side adds up to a total toe-in of 2°50' whereas they have just done 0.85x2 = 1.7 which is treating it like decimal degrees
  22. superkarl
    9,571
    2,464
    might do some research into what it might mean and how they've measured it. i've just been told its minutes not degrees.
  23. Alex C
    3,294
    372
    i was wondering if they said it was minutes not degrees to make the absolute error appear smaller, either way its clear your rear tyre wear is abnormal and highly likely to be caused by your rear wheels spinning in a plane not aligned with the direction of travel... good luck getting it all sorted
  24. superkarl
    9,571
    2,464
    ready for action now:
    Studs: SN90767801
    Nuts: SN10209009
    Gasket: 8L9253115A
  25. Wingnut Express
    Wingnut Express Audi sponsored by Mastercard
    124
    Is this gasket for the K04 with 3" downpipe? As just wrongly ordered one and it was smaller at 2.5?
    Thanks mate
  26. superkarl
    9,571
    2,464
    it is yeh. mates up with the downpipe perfectly
  27. Wingnut Express
    124
    Diamond, as I am having mine fitted Saturday week.
    Are you happy with the difference the downpipe makes or is still to be fitted. Good luck getting things sorted with Awesome mate
  28. superkarl
    9,571
    2,464
    im fitting it soon, unsure exactly when.
    but im not looking forward to doing it, but im sure il be more than happy with the results
    slowcoach3 likes this.
  29. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,234
    386
    Regarding Awesome and their wheel alignment skills, I have sacked them off completely.
    After 4 wheel alignments, all different readings, they still couldnt tell my why my car pulls to the left.
    I wouldn't let Awesome touch my car with a bargepole after the poor fobbing off service I received from them.
    I know of couple of decent places for 4WA. Audi in Trafford recently did a very good job on mine.
    There is also National Tyres in Altrincham who have a fulll geometry computer alignment system, not just the laser alignment things.
    Finally http://www.abpmotorsport.co.uk/they specialise in Honda but know there stuff when setting up geometry and wheel alignment.
  30. superkarl
    9,571
    2,464
    thanks dan.
    i know of others that have the same view of them.
    shame, with both our cars, by addressing problems and noticing these things themselves they can create more work for themselves = more money for them and more respect from us for taking good care of our motors.
    il save my final conclusion on all this till i've been to see them though. im sure they will be helpful and want to rid themselves of me lol.
  31. superkarl
    9,571
    2,464
    as posted in the fmic thread, heres a sneak peak of todays, and yesterdays work:
    more when its finished.
    mot ran out today, got alot of work to do this weekend to get it up and running and ready for a test next week.
    should go through fine, as long as they only advise the rear tyres.
    want to get to awesome gti next week at some point. right now its not possible
  32. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    They look like very comfortable trainers Karl. Did they match your tracksuit or are they the ones you feel most comfortable running away from the police in?
    Also, get some more pics of the fmic install up
  33. Dani_B19
    9,343
    394
    [HR][/HR]Gay lord drop out. Ive gone for the 76mm to 63mm silicone and still kept the fogs :), mans way son haha.
  34. superkarl
    9,571
    2,464
    right, update.
    i wont go into loads of detail as its already very well documented.
    half now, then a little more when my bloody camera battery is charged.
    after the usual hacking of the crash bar, you should want to set the height of your cooler:
    now with my cooler, with its welded on pipes i hit this snag:
    the cooler wasnt at the height i wanted at this point, and the pipe was clearly going to foul this chassis leg/towing eye, especially with silicone on it.
    now most intercooler installs the drivers side pipe will be angled down slightly to avoid this, but mine had been welded on straight (no fault of the welder, there was no car to mock it up to), so my cooler would have to be fitted lower than some to accomodate this issue.
    a pursuader soon had it sorted:
    id hammered in this area to make a bit of space
    as shown, now alot more space for silicone to go on
    now i mocked my silicone hoses up:
    very neat and tidy, i was impressed with how it came out.
    my next issue was that because my cooler couldnt be mounted as high as some, the brackets supplied were a little too big. so off to have them modified. where the comment was made, 'who made these? they cant half fkn weld' :)icon_thumright:dave)
    once the brakets were shortened a tad i was back home bolting it up.
    more pics once my camera battery is charged a bit
  35. superkarl
    9,571
    2,464
    and the rest
    and now to get the bumper on.
    looking at it and how tidy it was and how snug the cooler fit etc, i thought 'ahhh this is gonna fit without much if any cutting'
    i was wrong
    as you can see, it doesnt need a great deal, just a bit off the grills and around the grills on the inside. i did make a start but im leaving the rest till tomoro as my mate has the perfect tool to do some fine detailed trimming.
    so i've left it like this till then
    when fitting mine, i just wanted it mounted as high as possible really, so that the cooler would clear the bottom of the bumper, i didnt want it so low it'd be touching the bumper and be vulnerable.
    i had no idea where the pipes would sit in the bumper, but where it is is fine by me.
    its clear this 63mm welded pipe silution is a good one for keeping the fogs, and it looks tidy.
    dani, how on earth you, or anyone else for that matter have kept the fogs with 3 inch silicone reducers is beyond me! lol. well done.
    get some pics up of yours. i know there is plenty done so far but more the better.
    il update my thread tomoro with pics of the bumper fitted, should look good and v oem at the front end.
  36. Dani_B19
    9,343
    394
    If i can put a drink down for longer enough ill upload the pics lol, its very tight mate, had todo alot of cutting.
  37. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    I've just bought some led fogs to replace the stock ones, they are only 1ch ish deep all in and pretty much a direct fit into the grill. That was running the larger 76mm silicone, no way I would have got stock fogs in there, just not enough room.
  38. Dani_B19
    9,343
    394
    Beach how could you not retain the fogs? I have and it was quite easy, the fog light area only needed minimum trimming!!
  39. beachbuggy
    1,931
    202
    Not sure, to be honest, not seen any others in the flesh so not got anything to compare it with. Also the LEDs ment I could route the pipe work how I want and didn't mean I had cut too much. The led lights where only £10 ish anyway so seemed the less hassle way of doin it. I also dropped 1 fog and it smashed, plus I can say I have upgraded led fog lights when actually I just took the easy option, think that classes me as a pikey:) they look good though and you wouldn't notice except for the brighter whiter light so I'm happy
  40. superkarl
    9,571
    2,464
    finished product:
    unfortunately the 3 inch outlets on core push the grills after as much trimming as possible, i did only have to trim this area though.
    a solution would have been to maybe knock the front of that 3inch inlet inward a tad before welding, but thats out the question now.
    I am VERY happy with this.
    car feels great!
    Jimgrim77 likes this.
