suns out air con issuse :(
bradh Apr 18, 2014
  1. bradh
    bradh Active Member VCDS Map User
    557
    58
    hi guys right sun was out today so i thought lets bang the air con on guess what no freezing cold air was last re-gassed at the end of last summer , it was never freezing cold so i was pretty suspect as it wernt working right so now im feeling i need to fix it this summer
    so my questions are why would it not work?? things popping into my head are leaking some ware pressure sensor (ware is this located) worse case the actual pump knackard
    iv run vcds lite and got no errors/ faults showing
    any help pointers most welcome
  2. quattrojames
    14,050
    574
    I take it your ECON light isn't on?
    Not sure how good VDCS Lite is for this sort of thing, a pressure sensor failure should show up though.
    Fluid leaked out? ECON light would be on if it had.
  3. bradh
    557
    58
    The econ light does light up when pressed
  4. quattrojames
    14,050
    574
    And goes out when the air con is on?
  5. CHEZ
    CHEZ moderately amusing Supporter
    4,171
    839
    So,
    Ok your econ light works! That's a good sign!
    Next step, when car is idling, and you turn a/c on, can you audibly hear and feel any difference?
    When the a/c kicks in when button is pressed, you should hear the a/c compressor kick in and a slight change in engine noise?
    If this is not the case, then possibly your air on clutch is at fault?
  6. bradh
    557
    58
    quick video is this right ??? sounds silly to ask but thought it might help with diagnostics :
    i can hear the fan motor in the car speed up when the button is pressed not checked in the engine bay as i cant press button and see if anything moves at the same time will try that in the morning when wife's back from work,
  7. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,179
    152
    Does it have a clutch, a lot of Audis have N280 valves. Our A6 had a knackered cable so it wasn't opening the valve when requested.
  8. bradh
    557
    58
    just thought id up-date this as iv ben having issuse with alarm sender i scanned a few other sections too and found this :
    now iv looked on the wiki on rosstech and cant find anythibg to do with this code can any one shed any light ??
  9. s3tby
    s3tby Member
    77
    bradh: what module did you scan to get that error?
    Not to hi-jack your thread but my symptoms are similar to yours. No freezing cold air and LO setting puts out the exact same temp with econ off or on.
    -econ light remains switchable and goes on and off no problem
    -when turning AC back on (econ light off) experience a slight dip in engine revs and interior fan speed picks up
    -AC pressure lines next to the bulk head (driver side) under the bonnet are freezing cold and I can hear them bubbling / hissing internally for a few seconds after turning the engine off
    -no codes that I can find in VCDS
    -have completed VCDS HVAC tests and all the interior motors and fans seem to be fine (can hear them whizzing about)
    -was regassed last year
    Need that sweet AC to keep the interior nice and fresh :cold:
  10. bradh
    557
    58
    To be honest iv no idea I was just scanning everything my vcds lite would let me trying to get to the bottom of another issue and this popped up
  11. s3tby
    s3tby Member
    77
    Going into measuring blocks I can see the compressor responding. Scrolling through the groups it's all green. The only thing to note is that the compressor torque (with the econ light off) is zero? bradh: posting here as I hope we can both get a resolution.
    econ light off (compressor on)
    econ light on (compressor off)
  12. bradh
    557
    58
    Buddy show me what your doing to get that up ill do same on mine and put screen shots up to compare
  13. s3tby
    s3tby Member
    77
    Fire up your VCDS, go into the HVAC module then go into measuring blocks (bottom left).
    Then click the UP arrow on each group. As you switch the econ light on / off you'll see the values change in some of the groups.
    There are about 17 reportable groups in the HVAC module you can scroll through with readable values.
  14. bradh
    557
    58
    Ok I measure the 3 you have up ImageUploadedByTapatalk1401039972.372680.jpg ImageUploadedByTapatalk1401039984.737901.jpg
    But before I started I checked for fault codes and got 2 new ones
  15. s3tby
    s3tby Member
    77
    I'm not getting any error codes at all. Don't know if that's a good or a bad thing...!
    When scrolling through your groups did you notice if your compressor torque was reported as zero? (with the econ light off)
  16. bradh
    557
    58
    To be honest buddy iv no idea what I'm doing hear lol witch ones do you want me to look at I'll take pics again
  17. s3tby
    s3tby Member
    77
    Your codes are suggesting to me that you might have a problem with the air flaps & motors under the dash (most are behind the glovebox). If you run the tests in the HVAC module it might tell you something.
  18. s3tby
    s3tby Member
    77
    Just keep pressing the up arrow in your groups (doesn't matter which group. I just used the top group). Soon enough you'll see COMPRESSOR TORQUE with maybe zero in green in it. All it is is the system telling you what it's running at and with in real time. Pretty handy. You'd have seen all the different temps and stuff as you went through your groups.
    I'd run the tests in the HVAC module though. Takes a few mins and you'll hear all the motors under the dash whirring away as they prove themselves to the system.
  19. bradh
    557
    58
    Compressor torque is zero with econ on and off ImageUploadedByTapatalk1401044164.188194.jpg
  20. bradh
    557
    58
    What do u mean run the test in hvac module ?
  21. s3tby
    s3tby Member
    77
    Go into the 08 -Auto HVAC module then go into output tests 03. Run each one and check everything is working.
  22. bradh
    557
    58
    Arrrrrtrrt iv only got the vcds lite so I can't check this bit :(
  23. M9RC
    M9RC Member
    41
    I have just had a problem with my air con fixed. It was the loom to the air con pump which had corroded and broke. Sometimes you can get led astray with a fault using software rather than checking the wiring, connections, etc.
    CHEZ likes this.
