sunroof has a mind of its own
ALPINE May 24, 2008
  1. ALPINE
    3,093
    keeps opening, closing without me touching a thing??
    WTF????
  2. The911SC
    The911SC Active Member
    1,032
    that will be the switch itself in the roof. Known issue as the copper contacts break or wear out. Pull it off and take a look, it will be quite obvious!.
  3. ALPINE
    3,093
    cool nice 1 the911sc. i thought it mite be as i wiggled the switch about and it started moving. my bass also sets it off which is quite funny, er... no it was not, tunes going, pissin down with rain and the sun roof opens!! lol
    i loves cars!
  4. Turbo Lag FTW
    Turbo Lag FTW Hate those none insured you know who types
    235
    Ive just had to pull out a chunk of plastic that was causing my sunroof not to close. Everytime the sunroof met resistance it opened again, Im just not sure that it wont happen again as it appears that the plastic came from one of the guide rails. And it looks awkward to replace/remove. I desperately need to get a digi camera so someone can give me an opinion on what I should do.
  5. The911SC
    1,032
    When I had the issue ages ago, I changed the whole light cluster (picked up for a fiver in the good old days of GTi international).
    May be worth phoning around..
  6. GSB1
    GSB1 Member
    283
    Clean the metal contacts with contact cleaner or similar. Common fault where this simple fix really works.
    http://www.audiworld.com/tech/elec.html
    Followed this procedure myself and it's not too tricky. I think the B6 also suffers from a similar issue.
  7. ALPINE
    3,093
    thanks gsb1, i have followed that link and now resoved the problem i think. all clicks of the switch work and every thing is sweet.
    thanks to turbo lag ftw also as there was a few dirty lumps of plastic on the runners!
  8. Bushen
    Bushen Driving with style
    52
    You think thats bad, i was sat in traffic in really really bad rain and the sunroof just fully opened and i was with a girl and well...yeh..you get the point...wet hair and see through top!!! alriiiggghhhtttt thankyou audi! haha :yahoo:
  9. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    This is the 2nd thread i've read where i've actually had the problem within weeks of reading it. Last time was the ABS ECU fault :-(
    Still, looks like a nice easy fix!
  10. Blue_Thunder
    1,776
    33
    Has anyone done this fix on a pre-facelift? I had a go earlier following the instructions on the Audiworld link, but found my unit to look completely different. The pre-facelift unit appears to be completely sealed.
  11. I had an 03 golf GTi. Put down the drivers window with the "one touch" and it would bounce at the bottom, set the sunroof to open and the two of them would just open/close until I turned the ignition off. Mental.
  12. GSB1
    GSB1 Member
    283
    I did this on a pre-facelift. Instructions were good for me.
  13. Blue_Thunder
    1,776
    33
    Weird, there defo weren't any visible screws on mine.
  14. GSB1
    GSB1 Member
    283
    You did follow the B5 article not the B6?
  15. Blue_Thunder
    1,776
    33
    How embarrassing...
    Thanks GSB1! I'll have another stab tonight... using the correct instructions. I'd gone and bought a small torx driver set as well, as the B6 fix needs a T9 bit. What a dumbass!
