sump sealant or gasket?
harvey01 Aug 27, 2012
  1. harvey01
    harvey01 Member
    523
    9
    as above i can get the gasket from euro car parts but ive not got a tps near me or will audi do it off the shelf ?
  2. S4 Muzza
    S4 Muzza oww! my giant blue head!
    356
    31
    OEM sealant is the way to go, part number is D176404A2. Found this on ebay, very good price. If i remember correctly i paid around 20 quid for a tube last year.
  3. <tuffty/>
    21,686
    4,116
    The 20v turbo doesn't use a sump gasket...
    Use the OEM sealent... anything lese simply leaks..
  4. Sam_
    Sam_ Down under
    3,038
    480
    You can get a gasket though Tuffty. There's a part number floating about. That said, I'm doing my sump pretty shortly (and pickup) and I've got OEM sealant to use.
  5. harvey01
    harvey01 Member
    523
    9
    got some today £20.97 raping sl~~s:wtf:
  6. <tuffty/>
    21,686
    4,116
    Yes, I am aware there is a gasket but never seen one fitted to a production car... not sure which 20v's they were made for or if its a third party part but no 20v I have ever worked on has had one or needed one... its an extra rubber bit that is likely to fail through heat/oil (and lets face it there is enough rubber bits on our engines already doing that without adding more) and an extra face for a potential oil leak...
    The only time I have seen one fitted was to a Mk2 Golf with an AGU 20v conversion... never replaced it though when we rebuilt the engine...
    VAG sump sealant is the most reliable method of sealing sumps I have used to date... not even Bills Ibiza sump leaks using this stuff and thats spanked around a track...
  7. harvey01
    harvey01 Member
    523
    9
    i used it tonight made shore i put plenty on so i dont have to do it again .Going to leave it overnight then fill it up and run it for a bit and fingers crossed
