Sump plug won't budge
Ian W Nov 28, 2010
  1. Ian W
    Ian W Active Member
    1,058
    12
    Hmm, had two goes at trying to do an oil change on he S3 but the sump plug won't budge !
    Any idea's of anything I can use to help free it up, how much pressure can I realistically put on this before it snaps or rips my sump apart due to my awesome strengh (i.e - my massive crack bar)
  2. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    Are you trying to undo the sump plug while the engine is warm?
    It made it easier when i did mine,
    Try penatrating fluid around the nut... but ive never needed it realy
  3. Ian W
    Ian W Active Member
    1,058
    12
    Yep, got it nice and warm last time I tried.
    I've never needed anything on sump plugs in the past myself, normally quick turn with the ratchet and there loose. I've not done any service work on this car before so its not my doing thats its so tight !
  4. Mpathe
    Mpathe 1st gear
    394
    as much presure as it takes to either free it or break it, a new sump cost me 38.99 from euro. but as a tip id replace the sump and while you have it off replace the oil pickup pipe as it hasnt had an oil change for a while and maybe slighty blocked.
  5. S3KO4
    S3KO4 Member
    850
    First I wish you all the best. But how about you give it a go when the oil temp is high after driving, and use the same bar extended leverage. Make sure you are actually loosening it up not the other way around. It can happen when you are upside down
  6. Ian W
    Ian W Active Member
    1,058
    12
    Thanks for the tips, think i'll have another crack at it next weekend I think !
  7. SamiG
    SamiG On Boost, ish.
    233
    Get a blow lamp on it dude :)
    Just make sure you have a spare sump plug when you do it as you don't wana be putting that one back in if it's causing trouble :icon_thumright:
  8. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Gentle tap with the hammer before turning. Impact normally frees them up.
  9. sportstractor
    sportstractor Chugger
    2,709
    indeed heat and the use of an impact driver should get it open. Worst case is a new sump which isnt a biggy.
  10. Broken Byzan
    13,244
    468
    If all else fails, drop the oil sensor out of the sump to drain the oil for now.
    Thats a big **** sump plug
  11. Welly
    10,696
    130
    Thinking outside the box there dude.... lol. I like it.
  12. Ian W
    Ian W Active Member
    1,058
    12
    15 mile drive to get it nice and warm and some WD40 got this out this morning :)
    Done a full service now except the fuel filter which doesn't want to undo on one side !
    Tackle that tomorrow I think.
  13. Barks
    Barks Member
    337
    A slight tap in the tightening (clockwise direction) can often do wonders
  14. Welly
    10,696
    130
    .... use the sledge.... lol
  15. Welly
    10,696
    130
    Glad it's out dude. :thumbsup:
