Sump and Oil pickup clean?
S3-Oski Apr 23, 2011
  1. S3-Oski
    S3-Oski Member
    484
    Hi, My car is up for a service, but I would like my sump cleaned and oil pickup cleaned, at the same time.
    How easy a task is this? If I took it into a local mechanic, would they have the stuff I need for it? Or would I need to order the bits for it?
    Or if there is anyone around Essex area who is competent enough at doing this, I would happily pay what it costs? Its something I do not think I would attempt myself.
  2. stacey bear
    stacey bear ST8C3Y
    200
    Its not a hard job, im going to do mine asap, you'll need some brake cleaner and some good gasket sealer as theres no sump gasket, its just silicon. If you do do it make sure you get an even amount of sealer round your sump before you re fit it. You'll need your oil and filter too. Most car parts places will have those in stock as there a common filter and grade of oil...
  3. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    Not a hard job, shouldn't take more than 1.5 hours.
    You need a 5mm long reach ball jointed allen, silcone sealant, such as hylomar blue, a degreaser and a socket set.
    My biggest tip is to remove the 3 allen bolts located next to the sump first, these are a right PITA and there's no point removing the other 19 bolts if you can't get these out. So do these first just to make sure you're not wasting your time.
  4. S3-Oski
    S3-Oski Member
    484
    Thanks mate, If anyone reads this and is around Essex, and can/wants to do this, I will happily pay what it costs, cheers
  5. barters3
    barters3 Member
    438
  6. S3KO4
    S3KO4 Member
    850
    Don't forget the oil return gasket, or if you are like me just use the same sealant all round.
  7. S3-Oski
    S3-Oski Member
    484
  8. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    My advice is to just buy a new pickup pipe form Audi.
    They are about £14, and that way it is CLEAN, not semi clean. I have tried cleaning out a pickup pipe, and you don't get as good a result as when you install a new one.
    Do it right, do it once.
  9. a8 tech back
    a8 tech back Member
    198
    to do this completely remove the rocker cover and scrape the **** out
    remove the engine breather and clean it out also replace the pipes
    replace the turbo pipe feed pipe
    scrape the sump out
    clean the strainer out
    flush the oil through with some cheap oil
    reassemble fit a cheap filter and fill with cheap oil
    run to normal temp and drain it
    now fit oem filter and long life 3 oil or mobile 1
  10. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Exactly what i was gonna say. Buy a new one from Audi.
  11. dmac626
    dmac626 New Member
    Sorry to point out the obvious guys, do all of the above if you fancy, but if you invest in a good oil additive/flush, add it to the oil through the filler cap, run ther engine for a good 15 mins, it not only cleans out the sump and strainer, but does all the internal galleries and the top-end at the same time. I've stripped the bottom end of a few Audi's after servicing with a good flush, and they've been spotless - brand new even. Cheaper alternative than parts and labour for the entire sump and strainer. Good flush cost about £10-15. Have a look about on t'internet for a good flush....
  12. Broken Byzan
    13,237
    465
    not all depostis can be removed with flush sadly, if it were as simple as adding a flush, don't you think we would take the easy option? LOL
  13. S3-Oski
    S3-Oski Member
    484
    Hi all, Does anyone know a good place/anyone in Essex that would do this for me in the next couple of weeks? Thanks.
  14. dmac626
    dmac626 New Member
    Stripped bottom end off an A4, an S3 and an R8 after flush. A4 had 78,000 on it, S3 near 100,000 and the R8 about 18,000. Surprised me chief. Were absolutely brand new. Went on to do the top end on the S3....same thing. Galleries were gleaming, no sign of the usual ***** everywhere. I've got a **** old Peugeot as a run around and flushed that before fixing the bottom end. Same story. Might just be jammy...???
  15. pj123
    pj123 Member
    307
    13
    dmac626 - were the A4 and s3 on long life servicing or annual/10k. My S3 is on 93k, oil has been changed every 10k so wondering if it is just cars on longlife that suffer from a blocked pickup or if I should do it when i next change the oil.
  16. JamJay
    JamJay Member
    188
    Thanks for the advice, certainly can't do any harm if it doesn't work I'd imagine. Can you recommened a good product?
