Sudden random major electrical woes
voteforpedro Feb 9, 2009
  1. andybnwc
    andybnwc Member
    752
    £15 philips dust buster thing did the job for me , i also removed the grommets from the drain channels and made even more slits in them . I also removed the pollen filter housing and re sealed it . Those drain hole grommets are rubish and clog up really easy , i dont really see the point of them to be honest
  2. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    The sunroof has 4 drains one in each corner, maybe they are what is to blame.
  3. voteforpedro
    voteforpedro Member
    632
    So I bought a Black and Decker Dustbuster but I think I need to dry it out a bit more first.
    When I leave the fan heater on in the car, should I wind the windows down so that the damp air can escape?
  4. aragorn
    18,444
    847
    hmm, i think if you wound the windows down all the warmth would just blow away?
    Perhaps try for a few hours with the windows up and see how it goes? or perhaps open one of the rear windows a crack?
    Be careful with the heater too, dont want you setting the car on fire! :p
  5. Caesium
    4,879
    I'd be inclined to remove all the trim and dry it out of the car, might be difficult but if a job is worth doing its worth doing properly, also with all the trim out you can see where the water is coming in. Otherwise all this may be for nothing.
  6. voteforpedro
    voteforpedro Member
    632
    I got the carpet out today with a little help from Stanley (knife).
    Now I will let it dry out and I can concentrate on getting the inside of the car bone dry and, oh yeah, finding the damn leak. I will put the scuttle back together and then hose the car down and see if any water leaks in. If not, we can assume it was the scuttle tray. :)
  7. Caesium
    4,879
    I'd check the sunroof drains as well mate
  8. voteforpedro
    voteforpedro Member
    632
    I checked the front ones, which are by one of the hinges (lower one I think) for the front doors, and they seem fine.
    I believe the rear ones involve a trip into the boot and/or removing the rear bumper... can anybody clarify?
