Sudden loss of power
Gordyb Sep 7, 2013
  1. Gordyb
    Gordyb New Member
    20
    Help, my 2008 1.9tdi has an intermittent fault where it has a sudden loss of power as if you had taken your foot off the accelerator, power loss can be a few times in a 2 mile trip or it can go a few hundred miles between doing it. When the power cuts off it looses power completely and revs drop to idle revs and sit there. If you pop the clutch in and then out it cures it and you drive on as normal. If you take your foot off the accelerator completely and the back on it it also cures it!
    The engine light came on after a few instances of this happening and when the code was read it was a MAP sensor fault. I replaced the sensor but it made no difference.
    any ideas what else I should try?
  2. towcestervag
    towcestervag Member VCDS Map User
    165
    you need to get a scan done
    it could be a simple thing like a pedal switch
  3. Gordyb
    Gordyb New Member
    20
    Hi, thanks for responding, I've had it scanned and the only fault showing was the MAP sensor as above. Any other ideas?
  4. AudiMafia
    AudiMafia Member
    403
    13
    strange, what about the crank shaft sensor? it happens to me car judders when driving it feels as i have taken the foot of the acceleration pedal
  5. Yonner
    Yonner Member
    155
    when you replaced the MAF did the lights go off on the dash? try clearing the faults , if that no good , unplug the MAf and try driving it see if the power delivery is better ?
  6. S3_Jacko
    S3_Jacko Well-Known Member
    1,734
    575
    Defo sounds like the MAF sensor to me too
  7. Gordyb
    Gordyb New Member
    20
    Hi, the fault code was for the MAP sensor so I've replaced the 2.5bar map sensor in the intercooler pipe and had the light reset. EM light came back on first time it juddered afterwards. Same fault when codes read again.
    Are you saying I should look at the MAF next?
  8. Gordyb
    Gordyb New Member
    20
    Can someone point me at a picture showing where this is so I can try this please.
  9. AudiMafia
    AudiMafia Member
    403
    13
    2012-Audi-A3-Coupe-Hatchback-2.0T-Premium-4dr-Front-wheel-Drive-FrontTrak-Exterior-Engine.jpg
  10. AudiMafia
    AudiMafia Member
    403
    13
    do this and see if you can see any difference in driving
  11. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    There will be a massive difference in driving, as when you unplug MAF on a diesel it will feel very sluggish- as if it was in limp mode.
  12. AudiMafia
    AudiMafia Member
    403
    13
    Never tried it but was showing what Yonner meant :)
  13. Gordyb
    Gordyb New Member
    20
    Tried this only sat on the drive - no difference with it plugged in or not at idle or revving on the drive - do I need to go round the block to test properly?
    Also, looking at my service history/receipts the problem started a few weeks after having the fuel filter replaced, is it worth checking I don't have a blockage or would that show a different code?
