Such a shame they only fit a cab!
Marc1 Apr 7, 2009
  1. Marc1
    Marc1 Member
    728
  2. quattrojames
    14,050
    575
    Didn't sell for £200.
  3. JamesS4cab
    JamesS4cab Well-Known Member
    1,190
    94
    Would have been worth it just to split - i need a new centre console as well!!
  4. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    111
    there relisted now and still no bidders
  5. maxvw
    maxvw Member
    30
    i ended up buying this thinking i would change my grey interior over to black,however after comparing the 2 colours i am going to stick with grey,i have however stripped both sets of seats down and used my covers on the electric the seats and put the black covers on my original none electric seats,so if anyone wants a cabriolet black none electric interior for only a couple of hundred quid give me a shout,there is carpet,centre console,dash,seats,doorcards,glovebox and from what i can see most interior plastic trims.
  6. sebbelcher
    sebbelcher Member
    53
    Clever idea. I'm not sure what you ended up paying for them but I'm sure it was a damn sight cheaper than Audi would have charged for 2 fully elec seats.
    How difficult was it to repalce the covers? Was there any stitching/gluing involved?
  7. maxvw
    maxvw Member
    30
    quite easy job to be honest,bit fiddly but everything comes apart easy enough with no stitching or gluing required anywhere,just got to figure out the wiring now for the" easy entry"switch and jobs a goodun! any idea how the easy entry works?on the manual seats when you tip the back the base slides forwards to give the access but on these electric ones the lever just tilts the back,there is a 2 way switch beneath the lever which i am guessing just moves the seat forward electricaly?
  8. dansansome
    dansansome Member VCDS Map User
    165
  9. maxvw
    maxvw Member
    30
    fantastic,thanks.going of that there is some kind of control module in dash,(J285 -
    Control unit in dash panel insert)plus mention of connecting into can bus...........wonder if it can just be wired straight into forward/backward switch on the seat base,the end result would be just the same wouldnt it,ie.to slide the base forward or backward?
  10. dansansome
    165
    i wouldnt like to advise you either way on that, as i dont know.
    i know my electric seats move forward and backwards using that switch, ONLY while the doors are open, and after the seat has been moved forward, the seat will automatically stop at the same position it was moved from. i think this is where the control module/can bus interface would come in.
    kufatec seem to do quite a lot of seat harnesses, but not sure which one you might need.
    good luck!
  11. maxvw
    maxvw Member
    30
    is the switch one touch operation or do you have to keep your finger on the switch?just checked on the kufatec site and could only find a*se warmer loom,dont suppose you have a link to the other looms do you as i cant see any.
  12. grim ree
    grim ree Old-n-crumbly
    65
    You have to hold the switch,forward or back
  13. maxvw
    maxvw Member
    30
    so i suppose it just wants wiring into the door light circuit so it will only work when the doors open,is there any sparks on here that can advise me?i am a mechanic by trade but useless on electrics and dont want to set my car on fire!!
